Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Engine bucking issue
  1. #31
    6,375
    Quote Originally Posted by 90 red sc View Post
    Pulled codes. KOEO 11. KOER. 41. 91 77 74. No check engine light came on.
    You may recall the following items have been replaced
    Plugs and wires DIS Cam sensor battery is less than 2 months old. Also starter and relay have been replaced. Tach still not functioning as it use to.
    The KOEO code says no issues. KOER codes make me wonder if the engine was warmed up fully before testing.
    About the tach - remind me, was that an original issue when the bucking happened, or did it start right after new DIS and cam sensor, or? Did you use the paste on the bottom of the DIS when you installed it?
  2. #32
    May 2004
    Marlton, NJ
    136
    I notice the tech issue when this started. Yes I put dielectric on the DIS. Could it be crankshaft sensor ?
  3. #33
    6,375
    When starting, is the upshift light on in the dash cluster?
    Without more evidence, it could be a number of things. Interesting this happened after new items.
    What kind of shape is the electrical harness in that connects to the DIS and cam sensor? Any damage or oil soaking?
    Can you check the crank pulley to see if it wobbles or feels loose?
  4. #34
    May 2004
    Marlton, NJ
    136
    No upshot light at start. Wiring harness not in best of shape. No oil soaking or issue with dampner. Any place to get replacement wiring harness or do you have to rebuild from scratch?
  5. #35
    392
    Quote Originally Posted by 90redsc View Post
    Good morning
    Check the routing of DIS harness connectors cam/crank sensor and the supercharger belt. An improperly routed harness can "rub" and eventually chafe through the wires. As for a replacement harness (other than the salvage yard) try the wanted/sell section of SCCOA, SuperCoupe Performance and or Spinning Wheels restoration section.
    Good Luck.
  6. #36
    Oct 2012
    34
    I'll check the wiring as you indicated and see what I find. If wires need replacement, do you know what gauge it would be?
  7. #37
    6,375
    The harness includes shielded wiring and has to be correct, just like factory. I'd do my best to find a replacement instead of trying to make one up. Check with the vendors sources Sam listed.
  8. #38
    Oct 2012
    34
    ok thanks for the help
  1. Bucking issues
    By Tony8470 in forum Technical Forum
    Last Post: 11-17-2010, 07:40 PM
  2. New Engine, Breakin Issues, Please Help
    By TheAWK in forum Technical Forum
    Last Post: 04-14-2010, 10:31 PM
  3. Engine Bucking/Tach Dropping
    By QuickMustang in forum Technical Forum
    Last Post: 02-16-2009, 12:17 AM
  4. 90 engine into 93 body, any issues?
    By Boostman23 in forum Technical Forum
    Last Post: 07-22-2002, 09:29 AM
