Results 1 to 10 of 10
Thread: Need abs wheel sensor
    Mar 2009
    Greenville, North Carolina
    63
    Looking for an ABS sensor. Pass. side front. Thanks
    1991 SC 5spd
    1979 F-250 4x4 SC(Supercab) 400 4bbl 8spd
    1988 18' Checkmate Exciter 225 Evinrude 24p Chopper
    PNW
    6,544
    What year...they have dissimilar connectors.
    Mar 2013
    Ohio
    21
    Ever try An get the old one out?! An install the New one without damaging it! What a pain!
    Mar 2009
    63
    Sorry forgot to put it's a 91. I had to beat the hell out of the lower ball joint bolt to get it out and I must have hit the wire because when I went to test drive the car the abs light was on. I figured no big deal I'll just change it out. When I went to buy one I found out they are obsolete.
    1991 SC 5spd
    Mar 2009
    63
    No, I never tried to get one out. Any advice?
    1991 SC 5spd
    Madison, Ohio
    17,574
    Depends on how much rust you have. Being in NC you might get lucky and it will come out. Up north here it's about impossible. I have some though if you still need one.
    Email me here.
    Sep 2012
    Raleigh, North Carolina
    651
    i took mine out, but i gave them away at some point or I would let you have them. I was able to get mine out with no major problem. That uses an external torx to bolt the sensor to the spindle if I remember right. I didnt have one on those sockets, but i was able to use vise grips to get the bolt out.
    Any idiot can make a Mustang fast...
    It takes a special idiot to make a Thunderbird fast!!!
    89 SC 4.3 stroker 384rwhp 473ftlbs
    Best ET 13.085 Best MPH 106.6... got some work to do!
    2016 V6 M90 Dyno Champ 2016 Mod 1 Runner Up
    Mar 2009
    63
    Abs sensor
    The car and me are originally from Long Island but I hate seeing that damn abs light on. Is it the sensor itself thats hard to get out or is it the hold down clamp? Because I've had that bolt out. The car is pretty clean for a northern car. Anyway I'd like to give it a try. If you could send me your info and a price I'll send you out a money order and my info. Smokintbirdsc@yahoo.com, Thanks Dave
    1991 SC 5spd
    PNW
    6,544
    Quote Originally Posted by SmokinTbirdSC View Post
    It's usually because the sensor has rusted/corroded in place, like it's been welded, so yes, hard to remove. Grabbing, if you can, and trying to twist risks damaging it...same with trying to drive it out. But if you're going to toss it anyhow, then that doesn't matter, just don't damage the hole.
    Try the usual tactics of marinating it with WD-40, etc. and/or a bit of heat. Once you get it out, use some fine sandpaper to clean the bore. You don't want the hole so big the replacement can move, nor so tight you can't get it all the way in. A thin coat of anti-sieze wouldn't hurt.
    Dec 2003
    Gloversville, NY
    362
    sensor
    I might have one out, I'll check in the morning
  1. need ABS wheel sensor - front passenger - 91 SC
    By sunny627 in forum Want to Buy
    Last Post: 09-11-2011, 12:05 PM
  2. ABS wheel sensors
    By 92superJRK in forum Technical Forum
    Last Post: 04-19-2005, 02:53 PM
  3. How do I remove the ABS wheel sensor from spindle?
    By racecougar in forum Technical Forum
    Last Post: 10-03-2003, 10:21 AM
  4. ABS Wheel Sensors
    By Katoom in forum Super Coupe Club of Ontario
    Last Post: 03-29-2003, 07:35 PM
