Results 1 to 4 of 4
Thread: Another Spark Plug Question
    Oct 2016
    Upper East Tennessee
    20
    I found info here on this forum that recommended plugs include the Motorcraft AWSF34PP or Autolite PP2544 (among others). My local O'Rielly lists the Motorcraft AGSF34FM for my 94 SC. The box calls it "fine wire platinum." Anyone know the difference between the two Motorcraft numbers? The AWSF number was not in their database. They did have the Autolites though.
    Pacific Rim
    6,701
    PP typically indicates dual platinum, which, in our cars, is used because of the waste spark system, where current flows from shell-to-electrode on one stroke, and electrode-to-shell on the other (waste).
    AGSF34FM might just be a recommendation that caters more to reduction of part numbers and/or perhaps just a cheaper version of dual plats.
    Oct 2016
    20
    In searching previous posts about spark plugs I found a review of the Motorcraft AGSF34FM that was not very good. The Autolite PP 2544 (the other forum favorite) is not available but the APP 5144 is. Guess I will give them a try.
    Jan 2003
    Woodbridge, VA
    5,170
    Ford did some number swapping a long while ago. I believe they got rid of AWSF. And I think the difference between the AWSF and AGSF was the metal material they used ASWF black AGSF nickel. Maybe Fast Ed will chime in.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
  1. Yes...another spark plug gap question..
    By FineLineMtrSprt in forum Technical Forum
    Last Post: 06-20-2007, 05:35 PM
  2. OK...another spark plug question...
    Last Post: 04-15-2007, 09:33 AM
  3. Spark plug question
    By thundermax in forum Technical Forum
    Last Post: 03-09-2006, 05:16 PM
  4. Spark plug question
    By OKThumper in forum Technical Forum
    Last Post: 02-16-2005, 01:10 PM
