Thread: rear knuckle install/control arm 1990
    Jan 2006
    HI Guys,
    swapped my shocks out, but missed a step during removal. I failed to mark the position of the lower bushings on the control arm. I'm guessing if I just install them, then lower the car, they'll be wrong now?
    Should I leave them loose, lower the car, then tighten them? I seem to real doing something like this on the front when I did the uppers on the front.
    Jan 2006
    I ended up ""simulating"" ride height. Using a jack, I lifted the lower control arm, this also helped install the the shock. I lifted until the car almost came off the jack stands, then tightened the bolts. I'll see how it rides?
    I think that should do it, as long as both rear corners were equally loaded.
    If it acts hinky when cornering, like it wants to load/unload as a surprise and/or doesn't sit level, you may need to give it another try later.
  1. Replies: 4
    Last Post: 06-04-2013, 08:52 PM
  2. Mark 8 Rear Lower Aluminum Control Arms
    By Orange Bird in forum Parts for Sale
    Last Post: 11-10-2009, 09:38 PM
  3. Installed control arm but...
    By Jake in forum Super Coupe Club of Florida
    Last Post: 01-09-2004, 10:49 AM
  4. Rear upper control arm bushings
    By axis in forum Technical Forum
    Last Post: 12-08-2002, 05:42 PM
