Will update post 1 once I get on a pc again.
Making woosh sounds since 2010!
Kurt K (e-mail)
SCCoA Member #: 443
'92 SC AOD -- 11.521s @ 116.748mph, 2.0 AR power
. . . . . . . . . -- 13.547s @ 101.01 mph, only w/ bolt-ons
'95 SC 5spd -- All Stock, except 17" Simmons wheels.
'90 SC 35th Anny 5spd -- 3rd owner, 16k miles
2 '89 XR7 5spd's -- on their way out, really!
Kurt K (e-mail)
SCCoA Member #: 443
I have a race weight of 4160! I still have auto seat belts iron diff iron Lca's electric seat motors etc. Alot of little stuff I could get rid of to shave some weight and not loose any functionality. Hell I could ditch the ride control computer to since I no longer have arc shocks. None the less that's a good pass and it looks like we are very close to an equal match in the1/4
Kurt K (e-mail)
SCCoA Member #: 443
You have bogart front runners don't you? I am rocking the SC Alluminum spares with radials. Also i switched from 26x10.50x15 et streets to 275/50/15 et radial pros and the diffrence is night and day! Unless you are running a 5 speed there is no reason to run a bias ply slick on these heavy cars. My friend andrew who has drag raced his entire life told me about these tires. He runs low 9s in his camaro with them (3750lb) and showed me slow motion video of his car lanching on an et street vs radial pros and its unreal how much silly stuff goes on with a heavy car on a bias ply. He shaved a couple tenths off his ET and 60' by switching to the radial pro. They feel like street tires on the big end and stick like glue off the line! i ran 30psi in them on my 11.741 pass and still got a good 60'
List updated
Royer, post in format and ill add you.![]()
11.741 @ 117.5 - J Royer 1993 SC 4.2 2.3whipple aod
10.89 @ 127.93 Mike CH 93 SC 347ci v8 pt76 turbo AOD
14psi run
https://youtu.be/T-uupfJiwps
updated........
Example 1)8.675 @ 165.21 - CMAC - 1994 4.5 SVO Twin Turbskies
Great example............now make it happen.....![]()
