Page 16 of 17 FirstFirst ... 6121314151617 LastLast
Results 226 to 240 of 241
  1. #226
    English, IN
    4,515
    Quote Originally Posted by Flex View Post
    A crowfoot wrench requires an additional amount of torque to compensate for the reduced leverage.
    Depending on the angle.
    That did occur to me though....it had to be done "by feel" so we'll just have to see what happens. I'd like to think that someone rebuilding a transmission would have done it right the first time, but it's possible it was under-torqued I guess. Hopefully it stays for awhile.
    Shootouts: '09 SS 1st | '10 Mod1 2nd | '11 Bracket 3rd | '12 Bracket 1st | 2013 | '14 Bracket 3rd | 2015 | '16 Bracket 1st & Mod2 2nd | '17 Spectator | '18 Freeze-Plug Champ
    Black '89 5spd - 281K miles, MPx, Alky-Inj ¦ 387rwhp, 438rwtq (new motor) ¦ Best 1/4mi:12.521, MPH:107.23mph (old motor)
  2. #227
    Aug 2005
    Paoli Indiana
    4,857
    I'm excited for my 30minute open-header cruise to Jacob's house after it's together! LOL!!!
    Lift + MIG + Jacob's entertainment factor = much more productive and comfortable!
    Don't forget AIR CONDITIONING and propper lighting instead of the amish candle thing you have going on lol
    93 SC Red Aod 4.2/2.3lwhipple 422rwhp 11.360
    2018 Shootout Pro Street Runner Up
    Coming soon new motor 2300 TVS etc..
    90 35th aod stock, 90 5 speed Bolton Build in progress
  3. #228
    English, IN
    4,515
    Quote Originally Posted by Jacob_Royer View Post
    Lolol...
    You’ll get me shunned for sure Brother Jacob!
  4. #229
    Aug 2005
    Paoli Indiana
    4,857
    I won't tell yoder
  5. #230
    English, IN
    4,515
    Worked on the car for a little bit of time yesterday...thanks to Jacob, got some solid steel pucks to use for motor mounts for the time being. 3" on the driver's side and approx. 2 3/4" on the passenger side gave the headers some clearance. This also let the trans mount end up closer to center in the crossmember. I didn't see any markings on the crossmember that denoted the direction, but did notice there is a small hole on the driver's side where the wire loom attaches....so it appears to be on correctly.
    Hopefully will be able to get the motor mount done tonight and start throwing all the accessories back on soon!!!
  6. #231
    English, IN
    4,515
    Motor Mounts are done!Name:  IMG_5045.JPG
  7. #232
    Mar 2003
    Edmonton, Alberta Canada
    3,062
    What are you actually going to use for motor mounts?
  8. #233
    Denver Area
    945
    If I had to guess I'd say the car is the motor mount
  9. #234
    English, IN
    4,515
    I suppose I'll be doing some Turbo-Chuck style mounts. The steel for mounts would be thick enough that my old timey arc welder would work well...lol. Grab some polyurethane pucks like are normally used for lift kits...I don't know.
  10. #235
    English, IN
    4,515
    Got everything buttoned up, fluids refilled and fired it up! I only ran it open-headers in the garage for a few minutes since it was almost bedtime for the kids. I'm not too happy with where the header collectors ended up, so hopefully I can make some adjustments to those tonight.
    Need to get it out and do some shakedowns....but time is running out before the midwest bash! Still need to put the SCT slot MAF in there and tweak the tune too. Anyone know how it compares to the factory Ford slot MAF? It should be a constant multiplier for kg/hr vs voltage.
  11. #236
    Mar 2003
    3,062
    I have a set of Chuck`s solid mounts for my brother`s car. Will be dropping the engine in soon.
  12. #237
    English, IN
    4,515
    I won't tell yoder
    I've got Yoder covered....he ain't talking now. If he does, a hand-drawn copy of this goes to the town council.
    [ATTACH=CONFIName:  IMG_5296.JPG
  13. #238
    English, IN
    4,515
    I took the car out driving a little more this weekend...been working on some little things here and there....vacuum leaks, reworking the MAF curve for the SCT MAF (4" tube + SCT BA5000?....why not?!) I won't lie, it's tricky working with it at the low end....Idle is around 0.6 - 0.7V and getting it to rev-down without dying was next to impossible. I wondered if letting adaptive make adjustments would help while tuning, and it does help alot. I need to work on the startup tables some....it's too rich especially when 40°F outside. Occasionally, it will still die at a stop sign, rather than idle down smoothly. I need to re-adjust the throttle body (back to what it was)....from experience, that helps the computer control the RPM more naturally, rather than a 2k rpm surge for a few seconds as you coast to a stop.
    WOT feels great, but is also too rich. I'm sure once I get the fueling straightened out everywhere, I'll be wanting to drive it all the time.
    Yesterday, Danielle and I took both of our SC's out to Palmyra...I didn't think to get a picture of both together, but I did grab an impromptu one of her:Name:  IMG_5400.JPG
    Last edited by DrFishbone; 10-21-2019 at 12:45 PM. Reason: none of your business, interwebs.
  14. #239
    Mar 2003
    3,062
    Nice, why are her reverse lights on? Was she backing up?
  15. #240
    English, IN
    4,515
    She missed a turn, pulled over and backed-up to chat. Yeah...we were discussing dinner plans...lol.
  1. Engine building question
  2. Engine Build up FAQ
  3. Engine build-up
  4. Budget engine build?
