Results 1 to 14 of 14
Thread: Hesitation\hard idle (sometimes)
    Oct 2004
    Metro Denver Area
    2,514
    Solved the problem, sold the car.
    Jul 2005
    394
    Good evening
    Fuel pressure test would the next troubleshooting step. Next would be inspecting/troubleshooting the MAF sensor.
    Good Luck.
    Oct 2004
    Metro Denver Area
    2,514
    Quote Originally Posted by sam jones View Post
    Good evening
    Good Luck.
    Quarterhorse shows the maf voltage moving as it always has so I don't think that's an issue. Have a fuel gauge on the test port, reads 30-40 at idle. Problem is car only has issues when driving around and occasionally at idle.
    Jul 2005
    394
    Good morning
    How is fuel pressure after shut down? Do pressures pass the leak down test?
    Oct 2004
    Metro Denver Area
    2,514
    Good morning
    Good morning,
    Yea, the pressure stays after engine is cut off. Might be worth checking again but the few times I did it was okay. Seems as though the Regulator and Injectors are holding pressure as they should. No odor of gasoline ever. Still leaning towards an intermittent pump or clogged filter. I'll see about changing filter today, no high hopes on that. My gut tells me I'm dropping the tank...
    Greenville, IN
    4,286
    Look at 34 seconds in....the computer starts dumping fuel for some reason....
    Matt Haub
    Oct 2004
    Metro Denver Area
    2,514
    Yea, I think that's because I'm playing with the pedal. That log was me pulling out of the driveway in reverse. Placing it in drive and then flooring it going nowhere. I then went back into the garage.
    I take it you're looking at the STFT 1&2 being high 29's?
    Not sure what to make of that. I'm wondering if that's what the computer is commanding but it's not actually happening? As you can see RPM is staying low. The IMAF and TP are in sync, but yea, STFT is high...
    Greenville, IN
    4,286
    You're either losing spark or fuel on that one side....the other bank looks to be running okay, but rich (looking at HEGO's....or IEGO's here) ....I think that rules out fuel pressure and fuel pump issues. Both STFT's are high in an attempt to fix the lean condition one of the O2 sensors is seeing (passenger side)....but in doing so, gets the driver side reading too rich and throws the code 173. I would have expected that you'd get a passenger side lean condition code, judging by the datalog.
    I'd check your O2 sensor wiring real close...it looks like it almost completely loses signal intermittently and starts adding fuel to fix its perceived lean condition, but instead is just bogging you down until the engine is running fast enough to use the extra fuel.
    It would be interesting to see what a WBO2 was reading too.
    Matt Haub
    Greenville, IN
    4,286
    Quote Originally Posted by 90coug View Post
    Your STFT's go bonkers before you played with the throttle (seee TP volts)
    Matt Haub
    Greenville, IN
    4,286
    Duplicate post....
    Matt Haub
    Oct 2004
    Metro Denver Area
    2,514
    Thanks, Matt. I think you might be on to something. I'll inspect the wires on the O2's and see what I can find. When referencing banks 1&2. Which side is 1 and which side is 2 ? I think I've always been confused by that. I've always assumed bank 1 was passenger side of the block.
    Also, code 173 is telling me right side is rich. Wouldn't that be passenger?
    Greenville, IN
    4,286
    I think whichever side has the #1 cylinder is bank 1. In our case, the passenger side.
    Have you reset the codes and gotten the 173 again? I'd rely on your datalogs more than your codes either way
    Matt Haub
    Oct 2004
    Metro Denver Area
    2,514
    Right, thanks for the clarification. So, I didn't find any issues with the wiring for the O2's. I then went back to the logs. There are times where bank #1 is adding fuel and bank #2 is removing fuel and the engine is doing nothing more than idling. So my inclination at this point is a massive air leak. All I can think of is the intake manifold gasket.
    I have reset the codes, yea. It keeps coming back and I'm not surprised by what I'm seeing on the ST and LT FT's. I mean, I see one bank high in the positives while the other is deep in the negatives. Adding fuel, removing fuel and that must be because it's drawing air on one side. I'm thinking the side where it's always adding fuel is probably the side the manifold has worked itself loose.
    The fuel filter isn't clogged and the engine is surely getting fuel so I don't think there is a fuel delivery problem at this point. Not ruling it out but it seems unlikely.
    PNW
    6,401
    Reading fuel trims can be a good debug method... Quoting off the 'net:
    Use Fuel Trim to Diagnose Vacuum and Fuel Delivery Leaks.
    With the engine idling, look at the Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT) values. Normal range may be high as plus or minus 8, but closer to zero is best. If the numbers are +10 or higher for STFT and LTFT, your engine is running LEAN. Rev the engine to 1500 to 2000 RPM and hold it steady for half a minute or so. If the fuel trim numbers drops back down to a more normal reading, it confirms the engine has a vacuum leak at idle. This is because vacuum leaks have less of a leaning effect on the fuel mixture as engine speed and load increase.
  1. Hesitation off idle
    By Douglas Walker in forum Technical Forum
    Last Post: 04-12-2010, 07:40 PM
  2. High idle, sometimes.
    By darnoldrs in forum Technical Forum
    Last Post: 12-09-2007, 08:48 PM
  3. no brakes, won't idle, rock hard pedal.
    Last Post: 09-01-2003, 10:05 PM
  4. Hard starting when warm and occasional miss @ idle
    By Edman1000 in forum Technical Forum
    Last Post: 06-10-2003, 06:15 PM
  5. why the erratic idle sometimes?
    By ddw350 in forum Technical Forum
    Last Post: 12-15-2002, 04:26 PM
