Results 1 to 5 of 5
Thread: Electrical Gremlin
    May 2009
    Mansfield
    305
    Electrical Gremlin
    The Thunderbird God is sending me a signal perhaps.
    89 Sc with 80,000 kms, no mods other than a ripper. On my way to work all of a sudden hard brake pedal, brake warning lights come on,firm ride light goes out as does arc,vmm dark,signal lights non functioning. Otherwise running normal but I pulled over after a minute. Will get a code reader this wknd. I have 4 mn12s so probably should have one. Any ideas? Realised I have to renew my membership so I can get at more info.
    Thanks in advance.
    Tom
    In my haste I forgot to mention on restart everything went back to normal.
    Pacific Rim
    6,701
    See http://www.sccoia.org/articles/anti-...raking-system/
    Most likely ABS needs a fresh accumulator, but could also come down to relay(s), ABS hydraulic pump motor, ABS pressure switch and/or the multi-wire ignition switch on the side of the steering column (just did that to cure the same symptoms), inside the dash. Tons of existing threads, including one very recent, so be sure to search.
    Not sure a code reader is called for in this example, but yes, good to own regardless.
    Good luck.
    Ken
    Greenville, IN
    4,390
    It's very likely your ignition switch needs replaced.
    Matt Haub
    Dallas, TX
    5,705
    Concur. The switch case expands (metal fatigue) over time until they start making loose contact. Thats when things shut off for no apparent reason.
    You can tighten the switch case up with zip ties, bailing wire, etc. or just replace it.
    Another hack is to rock the key back/forth slightly when this happens to see if it will clear up long enough for you to get home and work on it.
    May 2009
    Mansfield
    305
    Thanks for the replies guys, It's definitely the ignition switch. I'll get a new one and swap it out tomorrow.
    Cheers Tom
  1. more electrical gremlins.
    By Lvcien in forum Technical Forum
    Last Post: 12-18-2005, 12:11 AM
  2. Electrical Gremlins
    By tbone in forum Technical Forum
    Last Post: 06-28-2005, 06:05 AM
  3. Electrical Gremlins.
    By Kris in forum Technical Forum
    Last Post: 06-16-2003, 04:30 AM
  4. Little Electrical Gremlin? Minor Issue?
    By syphon in forum Technical Forum
    Last Post: 03-14-2003, 11:36 AM
