Results 1 to 2 of 2
Thread: Oil fill tube removal?
    Jul 2004
    Indiana
    128
    Never mind, this thread can be deleted!
    How does that fill tube come off?
    It is in the way of removing the throttle body.
    Found old threads after I posted.
    Looks like a Ford design to keep us from working on our cars!
    Roanoke, Virginia
    3,186
    Quote Originally Posted by cougarxr7 View Post
    Should be an 8mm headed clamp holding it to the valve cover.
    Or remove the top studs from the plenum...can use the double nut method to unscrew em. That gives ya just enough room to rock the TB off the bottom studs.
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
  1. Oil Fill Tube
    By STEVE29 in forum Technical Forum
    Last Post: 01-24-2011, 06:31 PM
  2. Oil Fill Tube
    Last Post: 01-23-2011, 11:11 PM
  3. Oil filler tube removal (Throttle body stuck)
    By Flynnt in forum Technical Forum
    Last Post: 08-09-2004, 03:05 AM
  4. cant get the oil fill tube out
    By rzimmerl in forum Technical Forum
    Last Post: 12-27-2003, 12:37 PM
  5. Super Charger Oil Fill?
    By wwwtbirdforumcom in forum Technical Forum
    Last Post: 07-22-2002, 02:06 PM
