Results 1 to 6 of 6
Thread: Identify rear axle ratio
    Jun 2017
    4
    Hi all,
    Just bought myself a 95 SC with a warmed up engine, dyno says 330 rwhp. Don't have the specs yet but it's moving along quite well.
    Looking at the door jamb data plate AX=9 and TR=LKKJJ. Been trying to decode but no luck. Any help appreciated. By the way car is
    a Canadian car with km/h speedo.
    Thanks,
    Matt
    Sweden
    Feb 2017
    15
    http://www.tccoa.com/articles/gears/gears.html
    The chart of axle codes doesn't list a code "9". Are you sure that's it?
    The L indicates a 4R70W transmission, the KK and JJ are the front and rear spring codes respectively.
    Tom
    Jan 2003
    Woodbridge, VA
    5,168
    If it is stock it is probably an open 3.31 for the auto cars. Thats what mine was.
    And 3.31 isn't listed in the Tccoa article so probably a good chance thats it.
    And the other 95 auto I have here has the code "9". But Id have to lift it to see if the stock tag is on the housing to see what that says.
    There should be a tag on the diff housing that will have the ratio on it. Would be something like 3 31 for an open 3.31 or 2L73 for a locker 2.73.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Feb 2017
    15
    I suspected that was possible, I remember A-Train posting about those cars years ago. Never was under one in person to see it though.
    Jun 2017
    4
    I'll get under the car later and check.
    Thanks
    May 2004
    Va. Beach,Va.
    7,017
    If all else fails jack the car up and spin the rear tire 1 revolution and count how many times the drive shaft turns............
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
  1. rear end ratios
    By tim in forum Technical Forum
    Last Post: 12-10-2002, 10:52 PM
  2. What is my rear end ratio?
    By blkthndr in forum FAQ Forum
    Last Post: 10-28-2002, 07:08 PM
  3. Rear end ratio 90 sc auto?
    By purpleshadow25 in forum Technical Forum
    Last Post: 10-11-2002, 12:37 AM
  4. Another rear end ratio question please?...
    By tbirdsc35th in forum Technical Forum
    Last Post: 08-11-2002, 04:12 AM
  5. Rear end ratio question???...
    Last Post: 08-02-2002, 07:38 PM
