Thread: Rear diff
    Jun 2017
    4
    Rear diff
    Is the reat diff (internals) interchangable with same from Mustang 8.8? Have a 95 SC.
    Oct 2006
    Valparaiso, Indiana
    378
    I believe the ring and pinion are the only interchangeable things from a solid axle 8.8.
    Greenville, IN
    4,329
    Disclaimer: I'm not an authority on differentials - particularly solid axle rear ends. But experience from shopping around and rebuilding my own....
    Most parts are interchangeable. The IRS has an additional set of axle bearings and seals for the half-shafts I think the pinon gear/bearing/etc. are all the same and the carrier bearings are the same too. The limited slip is the interchangeable, but the side gears aren't machined for the axle circlips on a solid axle rear end (but can still be used). Ring and pinion gears are interchangeable.
    Matt Haub
  1. rear diff ?
    By strong6 in forum Technical Forum
    Last Post: 03-08-2003, 01:58 AM
  2. manual to auto rear diff????
    By Blue89SC in forum Technical Forum
    Last Post: 12-19-2002, 07:58 PM
  3. Leaking Rear Diff?
    By FearThis SC in forum Technical Forum
    Last Post: 12-07-2002, 10:57 AM
  4. Rear Diff....
    By stephens89sc in forum Super Coupe Club of Western Canada
    Last Post: 09-11-2002, 02:17 AM
  5. Rear Diff pinion seal replace or good mechanic in east GTA
    By tmnsheppard in forum Super Coupe Club of Ontario
    Last Post: 05-31-2002, 03:44 AM
