Thread: cam end play?
    Oct 2016
    16
    cam end play?
    I'm tearing down a 89 SC engine and when i was moving the gear off the cam i noticed it seemed like it had quite a bit of end play. Most of my experience has been with the mod series engines so not sure what is an acceptable amount (looks around 1/16th an inch. Also does the Connecting rods have TTY bolts? and do they come with numbers stanmped on the caps and rods from the factory or has this been apart before?
    Madison, Ohio
    17,582
    End play is measured with everything assembled. Yes, the rods are stamped from the factory.
    Email me here.
    Oct 2016
    16
    alright guess i'll put a dial indicator on it when i throw it back together.
  1. can i get a lopey idle and keep my botton end torque? cam time
    By 22lbsofboost in forum Technical Forum
    Last Post: 07-01-2015, 08:13 PM
  2. Cam sensor gear flush with end of CAM??
    Last Post: 03-04-2006, 11:03 PM
  3. Will you have your sc out to play in the snow?
    By robsuperbird in forum Polls Forum
    Last Post: 05-24-2005, 09:18 PM
  4. cam sensor
    By Superbird1 in forum Non Technical Forum
    Last Post: 05-23-2002, 11:09 PM
  5. front end?
    By intercooled 89xr7 in forum Non Technical Forum
    Last Post: 05-17-2002, 09:37 PM
