Results 1 to 4 of 4
Thread: anti-lock
    ny\long island
    2,679
    anti-lock
    hi guys n gals my anti-lock brake light (amber) came on a month ago (93 sc daily driver). the front driver wheel speed senser was locking up..so i replaced it , and the relay (under driver fender. still light is on. check the fuse box ( in car ) ahhhhhhh i found the problem.........2 fues later it keeps blowing i put my snap on scanner to the anti lock plug (driver shock tower) . no responce. maybe a short somewhere or the main anti lock computer has failed? any help guys i would be happy to hear. thx tony.
    Norcross, GA
    3,314
    It sounds like the motor bearings have locked up or the brushes burnt out. Either one could have happened. There is a plug for the motor on the fender side of the ABS unit under the hood. You can jumper the pump to see if it'll run by itself. Go online and find Duffy Floyd's ABS article from Charging Thunder magazine.
    Roanoke, Virginia
    3,270
    93 doesn't use the Teaves System...So not sure that would work...
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
    Norcross, GA
    3,314
    Ah, I see that now. I've got lots of parts from 2 different 94s. If you end up needing anything let me know and I'll see if I have it.
  1. anti -lock light?
    By tim in forum Technical Forum
    Last Post: 08-16-2003, 11:05 PM
  2. Anti-lock brakes? Or...
    By Billabong089 in forum Technical Forum
    Last Post: 08-12-2003, 04:37 PM
  3. "Brake" and "Anti-Lock" lights lighting up?
    By syphon in forum Technical Forum
    Last Post: 06-19-2003, 02:37 PM
  4. Anti-lock light on.........[kinda' long]
    By z90sc in forum Technical Forum
    Last Post: 05-06-2003, 03:11 AM
  5. anti lock brake light
    By kluxman45 in forum Technical Forum
    Last Post: 07-28-2002, 09:18 PM
