Results 1 to 5 of 5
Thread: First real hot day with the coupe, damned power lose sucks :(
    Jul 2016
    64
    So it's hitting into the high 30's in the Okanagan valley. The supercoupe doesn't like the heat so much, noticed a couple times leaving lights and go to wind up the car (auto) no real suck you back into the seat. So have to stay out of the boost or else she'll start running a little warm.
    A couple things i need to do, is to change the coolant, thermostat. Then maybe look at running a switch into the car so i can control the fan a bit more or even upgrade the fan Not sure about options for that aspect. Look at the double intercooler option or even go with a fan set up or both.
    Now i'll be looking at options to keep this car cooler in the summer time heat.
    Now one thing i'm curious about and seen it on the new dodge demon is to run the AC plumbing into the IC, seen you can get a kit for the Mustang supercharged variants. Wonder if you could do the same thing on the coupe?
    Aug 2004
    2,027
    If you are running hot at that temperature and your radiator and thermostat is good, you better check the fan's functionality. There's a low and high speed for the puller fan. Run diagnostics and report back.
    Jul 2016
    64
    Yeah, gonna look at the fan and make sure it's running as intended. Just too damned hot out to do anything
    Aug 2004
    2,027
    Where do you live? Summer is here and 30c degrees isn't much.
    Jul 2016
    64
    In vernon bc. It was sitting around 35c the last couple days. Just the first real time i have driven a supercharged car in the summertime heat. At least the AC works good
  1. First Day With the SC on the Road all detailed up
    By jjklongisland in forum Non Technical Forum
    Last Post: 08-07-2013, 11:51 AM
  2. First time at GIR with the new car/mods
    By CurtisPaulfrey in forum Racing/Track Results
    Last Post: 10-04-2008, 12:51 PM
  3. last track day with the aod
    By TwoToneThunder in forum Non Technical Forum
    Last Post: 10-23-2006, 10:25 PM
  4. First road trip with the s/c.
    By Jacob_Royer in forum Non Technical Forum
    Last Post: 09-19-2005, 02:56 PM
  5. First really cold day with 90 sc
    By flopes64 in forum Technical Forum
    Last Post: 11-01-2002, 01:07 PM
