Results 1 to 13 of 13
Thread: Cougar in 24 hrs of Lemons.
    Jul 2005
    Palos Heights
    2,294
    Ok.......either here or tccoa there was someone running a Cougar in 24 hours of Lemons. They swapped in a Windsor V-8 and kept the M2r2 trans/etc. Anyone have an idea who that was?
    PNW
    6,375
    Jul 2005
    Palos Heights
    2,294
    Cougar
    Yes........as I recall it was him. I have a question about what clutch, starter and flywheel he used.
    Feb 2003
    Tinton Falls, NJ
    1,505
    Yes that was me. The flywheel, clutch, and starter were all ordered for a 95 Ford F150 with a 5.0 and a 5-speed.
    You can also use all the SC stuff if you have the flywheel rebalanced to match the 5.0's 50oz imbalance.
    Jul 2005
    Palos Heights
    2,294
    swap
    Excellent........Thanks.
    Jul 2005
    Palos Heights
    2,294
    swap
    Did you use or adapt anything from the factory ignition?
    Feb 2003
    Tinton Falls, NJ
    1,505
    No. When we first put the car together, we ran the motor carb'd and used an HEI distributor adapted for a Ford. After 2 races we knew the carb setup was junk in terms of holding together for an endurance race, so we converted to EEC-V and OBD2 using everything from a 5.0 Explorer.
    What exactly is it you are looking to do?
    Jul 2005
    Palos Heights
    2,294
    swap
    Want to go to a v-8 and store the 3.8
    Feb 2003
    Tinton Falls, NJ
    1,505
    Well if it is going into an 89-93 car, the easiest way would be to use all the 91-93 Tbird/Cougar wiring and ECM.
    Jul 2005
    Palos Heights
    2,294
    swap
    I have a 94'.......so either a stand alone efi system or a good old Holley.
    Feb 2003
    Tinton Falls, NJ
    1,505
    In that case, I would get a 94/95 4.6 Tbird donor car, and use the engine wiring harness from it, and repin the ecm connector to use a 96-00 Explorer 5.0 ecm. That way the 94/95 wiring harness will work with your existing dash harness, and you can get OBD2 and DIS at the same time. This would involve some wiring work on the 4.6 engine harness to make it fit the 5.0, but probably no harder than a stand-alone wiring setup, and much cheaper!
    Mar 2011
    SF, CA
    214
    Quote Originally Posted by CougarXR/7 View Post
    I have a 95 tbird w/ a 302 swapped in from a 93 donor.
    http://forums.tccoa.com/8-engine-5-0...s-learned.html
    My wiring setup is as follows: 93 tbird engine harness, 93 tbird ECU harness, 93 tbird ECU, 95 tbird dash/chassis harness + gauge cluster (needed because I still wanted to support the ABS in my 95 chassis), 93 tbird tach in 95 tbird gauge (needed because my chassis is a V6). You can see my documentation of all my wiring changes which will be similar to your 94 chassis.
    Tuning can be done with quarterhorse (OBD1). You can also upgrade the ECU to one from a 94-95 mustang if you want (effectively making your car a 94-95 5.0 Mustang as far as engine tuning goes) with a little tweaking
    Here's my writeup on tuning basics with QH for my current setup (I still use the 93 tbird ECU since it does everything I want it to do and my engine is pretty "mild").
    http://forums.tccoa.com/12-eec-tunin...se-basics.html
    Good luck
    7,562
    Solid info there, good post.
    Would be cool to see more MN12s out in LeMons and Chumpcar.
    cheers
    Ed
  1. Replies: 0
    Last Post: 10-28-2002, 07:07 PM
  2. Interested in meeting some of you
    By SUMFEAR in forum Super Coupe Club of Northern California
    Last Post: 04-08-2002, 07:56 PM
  3. In case any of you ever wondered...
    By Kick Ass Kolenc in forum Super Coupe Club of Western Canada
    Last Post: 04-03-2002, 06:34 AM
  4. Join me in the rebirth of my car aka phoenix
    By flynbrd in forum Super Coupe Club of Northern California
    Last Post: 01-29-2002, 04:45 AM
