Thread: Lower control arm
    Jul 2004
    Indiana
    128
    Lower control arm
    Has anyone ever had an issue with a new aftermarket lower control arm ( thanks BirdofPrey97!)?
    With it being new, the ball joint is so tight that the spindle is unbelievable stiff?
    I got the rack off, now the spindles are free flowing.
    Putting the passenger side wheel back on is when I notice how stiff that spindle was.
    It was so stiff, it took some muscle to move it!
    I am tempted to put it all back together and disconnecting that lower control arm to see if I get power steering back.
    I thought I'd chime in and see if if this has happen to someone before.
    I find it very hard to think yet believe a ball joint being so stiff it could stop the power steering from working!
    My previous post concerning this.
    http://www.sccoa.com/forums/showthre...power-steering
    May 2012
    Oregon
    780
    Did you try moving the ball joint by hand? I need new lower control arms and have feared the opposite - immediate slop. I've been thinking about going with new bushings and rebuilding what I have. Are you seeing zero movement or just very limited?
    Jul 2004
    Indiana
    128
    Yes!
    Could not budge.
    Used a pair of vice grips and was able to move it, but it was tight!
    I plan on buying a new motorcraft rack from rock auto.
    Put it all back together and see what I get.
    I cannot believe how difficult ford made it to fix their cars!
    Tried posting some pics, kept failing, with no explanation!
  1. Lower Control Arm Shock Mounting Bushing.
    By Greg in forum Technical Forum
    Last Post: 01-07-2003, 01:20 PM
  2. Replies: 3
    Last Post: 01-03-2003, 07:40 PM
  3. Replies: 4
    Last Post: 11-26-2002, 11:40 AM
  4. Lower control arm buying info
    By cary Jackson in forum Technical Forum
    Last Post: 10-13-2002, 08:34 PM
  5. Lower control arms
    By pepito6SC in forum Technical Forum
    Last Post: 07-17-2002, 08:05 PM
