Results 1 to 5 of 5
Thread: Rear main seal
    Feb 2013
    bohners lake wi
    115
    Rear main seal
    Well I finally got around to pulling my transmission out and I am looking for some advice on replacing the rear main seal. I have never changed a 1 piece like this before. It doesn't seem to be leaking but I figured it would be good to change it now. Is this a good idea or am I opening up a can of worms.
    Jul 2005
    394
    Good afternoon
    Yes change the seal. Check first for a previous installed rear crankshaft sleeve. If it was installed and you have no indication of a leak I would leave it alone. If the sleeve was not installed doing so will ensure the seal rides on a smooth non defective surface.
    https://www.youtube.com/watch?v=bKayjFhOXc4
    Good Luck.
    Feb 2013
    bohners lake wi
    115
    Jul 2005
    394
    Good evening
    Yes the seal and sleeve will work. I would order from ROCK AUTO for a better price.
    Feb 2013
    bohners lake wi
    115
    Will do. Thanks again for the advice
  1. Rear Main Seal Replacement
    By sail7seas in forum Technical Forum
    Last Post: 06-08-2006, 12:37 AM
  2. Quick rear main seal ??? PIC
    By Bigme574 in forum Technical Forum
    Last Post: 08-01-2003, 07:16 PM
  3. Rear Main Seal
    By Phantom Menace in forum Technical Forum
    Last Post: 06-23-2003, 12:53 PM
  4. Rear Main Seal Install?
    By wezar in forum Technical Forum
    Last Post: 06-08-2003, 01:55 AM
  5. Rear Main Seal
    Last Post: 11-24-2002, 05:41 PM
