Results 1 to 3 of 3
Thread: ARC Actuators - interchangeable between 1990 & 1994?
    Nov 2009
    can the ARC shock actuators from a 1994 SC (F4SC-18B012-AA) fit & work properly on a 1990 ( E9SC-18B012-AD). The connector ends look identical however the different part number is causing me doubts. If someone knows for certain would be great to know. Thanks in advance
    AA vs. AD illustrates a running change to the same part over time, where AD is the newer version that may or may not include minor changes (different supplier; updated components based on cost, material, regulation, etc.), typically during production over time, where the dealer would be informed to replace AA etc. w/AD. I can think of dozens of reasons for such changes that wouldn't specifically matter to day-to-day operation on a vehicle.
    The same shocks fit all years - the electrical operation of the actuator is just to energize a small solenoid that pivots the drive coupler. The ARC module checks resistance across each actuator circuit and if outside spec, the light flashes in the cluster, telling you which corner isn't happy. You'll know as soon as you turn the key ON, so watch that light in the cluster.
    As long as the main P/N is the same, I'd be happy if I could find AD
    Just be sure to keep the receipt.
    Caledon, Ontario ... CANADA !!!
    They are interchangeable all the way through 1989-1995. When I look at the Ford parts catalogue, the E9SC version used originally on 89-93 was replaced by the F4SC version used on 94-95.
  1. ARC actuator came off
    By rph1966 in forum Technical Forum
    Last Post: 05-25-2005, 10:46 PM
  2. ARC actuator
    By asystole in forum Want to Buy
    Last Post: 05-08-2005, 11:57 AM
  3. how much are ARC actuators?
    By Jeremy_K in forum Non Technical Forum
    Last Post: 06-20-2004, 11:23 PM
  4. ARC Actuator and Shock Tower (Leak???)
    By BlownMerc in forum Technical Forum
    Last Post: 08-13-2003, 01:23 AM
  5. ARC Actuator Question:
    By Mitch90BlackSC in forum Technical Forum
    Last Post: 10-10-2002, 10:31 PM
