Results 1 to 9 of 9
Thread: Slip yoke
    Feb 2013
    bohners lake wi
    115
    Slip yoke
    Does anyone know where I can get the yoke that goes into the transmission? The only one I could find was a strange brand for $230.00. mine has some pretty bad grooving around the seal area. It did not look like it was leaking but I would think I should replace it while I have the car apart.
    Jul 2005
    407
    Good morning
    Might be a indication of a out-of-balanced shaft assembly and or bad transmission mount. You could remove the whole shaft assembly and have it inspected and re- balanced at your local drive shaft shop. You could also get a used complete shaft assembly at your local salvage yard(s), SCCoA forums and or TBShop, SuperCoupe Performance, Spinning wheels ect. If you get a used assembly have it inspected and checked for balance at a drive shaft shop for peace of mind.
    New after market replacements are very expensive.
    Good Luck.
    Feb 2013
    bohners lake wi
    115
    I was hoping to get just a factory yoke if anyone knows of the part # I think the transmission mount was bad it was very loose/rubbery compared to the new one I bought
    PNW
    6,589
    Quote Originally Posted by Csirny View Post
    ...mine has some pretty bad grooving around the seal area.
    I'd think you could sleeve it for much less $$...
    Feb 2013
    bohners lake wi
    115
    I guess I didn't consider that. I'll look into it and see what I can find for a sleeve
    Norcross, GA
    3,314
    I have a practically new one that came from a 4R70W. No grooves.
    Feb 2013
    bohners lake wi
    115
    I found one that I think will work for $70.00. it's a Spicer 1330 series. I have a 5 speed is the one you have the same? How much would you want for it?
    Norcross, GA
    3,314
    Naw, they're different. This one is thicker in circumference and won't fit inside of a 5 speed.
    Feb 2013
    bohners lake wi
    115
    Here is what I found. Everything is the same except the barrel length and length to the center of the U-joint is 1/2" shorter than the factory yoke
    http://www.dennysdriveshaft.com/p91_...4_auto_t_.html
  1. WTB Slip yokes (2)
    By Plat0ribs in forum Want to Buy
    Last Post: 04-17-2012, 08:16 AM
  2. Drive Shaft Slip Yokes
    By BirdofPrey97 in forum Non Technical Forum
    Last Post: 04-02-2012, 09:21 AM
  3. Shattered slip yoke
    By 90coug in forum Technical Forum
    Last Post: 03-10-2007, 09:52 PM
  4. Slip Yoke
    By Chris89cougar in forum Technical Forum
    Last Post: 03-03-2003, 12:38 PM
