Thread: ecu install/fit/ harness routing
    Jun 2011
    San Diego
    409
    Hey gang. I need help with a pic of the ecu installed up in the kick panel with wire routing. I got the car without the engine or harness or ecu. Its running fine but i have the computer laying on the floorboard... no bueno if a passenger gets happy feet especially with quarterhorse sticking out. I don't want to just jam it through where i i guess it goes and zip tie. Right now the harness seems to occupy where the ecu should be. Tried a couple searches and no luck.
    May 2004
    Va. Beach,Va.
    7,001
    I don't know if this helps..................
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
    Jun 2011
    San Diego
    409
    I think so. Once i'm under the dash it should start to make sense. Thanks!
  1. Door wiring harness routing
    By ecyrbh in forum Technical Forum
    Last Post: 05-30-2017, 11:10 PM
  2. Need good picture of wiring harness routing by oil filler
    By 90turbo1 in forum Non Technical Forum
    Last Post: 10-13-2010, 01:47 AM
  3. ECU and Engine Harness needed
    By fatdaddy in forum Want to Buy
    Last Post: 09-28-2008, 07:38 PM
  4. 5-point harness installed!
    By quick35th in forum Technical Forum
    Last Post: 05-23-2004, 12:36 PM
  5. 5-point safety harness installation
    Last Post: 05-19-2004, 12:54 AM
