Results 1 to 9 of 9
Thread: abs light..
    Aug 2004
    Canada
    256
    abs light..
    I have a low mileage 1991 SC that has been in storage for a about 3 yrs or so. and recently I notice the abs light stays on when I start up the car. It used to go out shortly after it is running. Just wondering what would cause the light to stay on?
    PNW
    6,586
    You'll want to see this page:
    http://www.sccoia.org/articles/anti-...raking-system/
    ...'Basic Troubleshooting'.
    Might be pump, relay, pressure switch, ignition switch, accumulator or combination of. Low hanging fruit is relay and ignition switch.
    You'll need to know if the pedal is hard, any work done to the ABS recently, etc.
    This comes up routinely [ see this recent thread w/over 100 posts... as an example], so feel free to search, then ask questions if you still have them.
    Good luck.
    Ken
    Aug 2004
    Canada
    256
    Ken
    Thanks for the infos.
    It has just been sitting in storage. no work has been done to it. as why I find strange what would cause the abs light to come on.
    PNW
    6,586
    Quote Originally Posted by JOE91SC View Post
    The car was over two decades old when it went in - corrosion on any of the electricals I mentioned is not so strange, I think. These cars don't like not being driven, so 'just sitting' can be a curse in this case.
    Did you run thru the ts link yet?
    Aug 2004
    Canada
    256
    Yes, briefly. The pump does run, and it does shut off. but it'll run again after the brakes is depressed only twice. I think I might need a code reader.
    May 2012
    Denver Area
    803
    You can jumper the ABS test connectors together with a paperclip and get the codes - no reader required.
    Aug 2004
    Canada
    256
    Where does it display the code?
    PNW
    6,586
    Given your description, I'd say you just need a new accumulator ball. Try Victor at http://spinningwheels-sc.com
    Going to be difficult to find an ABS code reader for that car, I think. A regular code reader using the test port under the hood isn't going to know about your ABS.
    Apr 2012
    Dallas, TX
    437
    If you do not have a code reader( basic odbI will work too) to plug in the trunk connector, use the paperclip method.
    The ABS light will flash the code
    https://m.youtube.com/watch?v=oMXvMShUYiI
    Check out my 1993 White Auto SC page for video on how to ..
    1990 35th anniversary SC restoration project
    1990 Blue Auto SC
  1. ABS lights on-no boost
    By Blown6 in forum Technical Forum
    Last Post: 12-11-2002, 11:55 AM
  2. about the brake and abs light
    By AnvSCMAN in forum Technical Forum
    Last Post: 11-17-2002, 05:17 PM
  3. Rear end thunk..ABS light ...
    By tbirdsc35th in forum Technical Forum
    Last Post: 09-13-2002, 07:49 PM
  4. blinking abs light....
    By HappyHourHero in forum Technical Forum
    Last Post: 07-21-2002, 03:35 PM
  5. Traction Control & ABS light problems
    By tbirdsc357 in forum Super Coupe Club of Ontario
    Last Post: 07-11-2002, 12:22 PM
