Results 1 to 4 of 4
Thread: Purchased Used Mass Air Flow Sensor (MAF) 'What did I buy? (Pics)
    May 2003
    Winnipeg
    64
Size:  400.9 KBName:  WP_20170724_20_20_13_Pro.jpg
Size:  411.2 KBName:  WP_20170724_20_20_23_Pro.jpg
Size:  408.9 KBName:  WP_20170724_20_20_33_Pro.jpg
Size:  408.8 KBName:  WP_20170724_20_20_46_Pro.jpg
    389
    Good morning
    You have purchased a late model Ford mass air flow housing and sensor. Note the "bridge" attached to the sample tube. In my salvage yard searches the housing is found on:
    1992 - 1997 Thunderbirds and Cougars. See attachment: http://www.sccoa.com/forums/showthre...re-recommended
    The Mass Air Flow sensor is a later model years (1991 -1995 for the S/C) as identified by the part number AFH-70-02. Earlier units can be identified with AFH -55 followed with a suffix number. Example. AFH-55-03B.
    The MAF housing is interchangeable for the SC. The sensor electronics are not as it calibrated to the stock unmodified ECU and fuel injectors.
    If you plan on using it (and are not modifying/tuning the ECU) you must first match with currently installed MAF sensor first. Then clean the two sensor leads with the correct cleaner.
    Hope this helps and Good Luck.
    Oregon
    768
    Sam Jones is my hero. This is not a joke.
    May 2003
    Winnipeg
    64
    Thank You, Figured it out
    This is a Lincoln MAF. I bought it off a wrecked Super Coupe in CA. I thought it was a C&L.
    I will have to keep looking for a 80mm or 85mm C&L with a purple tube.
  1. Wanted 1994 4.6 mass air flow sensor
    By brian p in forum Super Coupe Club of Ontario
    Last Post: 09-07-2011, 11:58 AM
  2. MAF Mass Air Flow Sensor for project
    By cp308 in forum Parts for Sale
    Last Post: 02-04-2008, 10:44 PM
  3. Cold Air intake and mass air flow sensor
    By Lsquared in forum Technical Forum
    Last Post: 03-20-2006, 07:23 PM
  4. 42lb calibrated mass air flow sensor, without housing
    By SuperCoupeSC91 in forum Want to Buy
    Last Post: 06-22-2005, 08:59 PM
  5. 70mm mass air flow sensor
    By KilswitchEngage in forum Technical Forum
    Last Post: 01-11-2004, 10:36 PM
