Results 1 to 15 of 19
Thread: 95 headlight bypass.
    Aug 2004
    2,026
    Is there a way to bypass the headlight running sensor that controls when the head lights come? I want them to come on all the time when you turn on the ignition instead of just at night and manually turn them off using the wheel.
    PNW
    6,588
    Well, you could always put tape over the sensor
    Aug 2004
    2,026
    If you are talking about the sensor on the passenger side dash, I already have tape over that one. The lights still do not come on daytime.
    PNW
    6,588
    Quote Originally Posted by rickbtbird View Post
    Pass. side? It's on the driver's side on early, but if that's it, it seems strange that has no effect. What else have you already tried?
    Jan 2010
    Bossier City, LA
    2,221
    It's still on the driver's side.
    From the factory service manual:
    The system light sensor amplifier :
    Assembly is mounted under a group of slots in the upper instrument panel (04320) in front of the driver.
    Must always be exposed to outside light to function properly.
    RwP
    Aug 2004
    2,026
    There's a group of slots above where it says premium sound. I taped that and no difference. Lights don't come on during the daytime.
    Jan 2010
    Bossier City, LA
    2,221
    No.
    Look down through the WINDSHIELD.
    See those sensors THERE?
    One is for the auto lights; one is the sun load for the EATC. (If you don't have EATC, you'll only have one, and it's even easier to pick!)
    Cover one; if that doesn't fix it, then uncover it and cover the other one.
    And while you're at it, uncover that one above the "PREMIUM SOUND" logo; that's the EATC internal temp sensor!!
    And when you get done with all that, GO PICK UP A COPY OF BOTH THE FACTORY SERVICE MANUAL AND THE ELECTRICAL VACUUM TROUBLESHOOTING MANUAL. NOW! Hie thee over to Ebay and pick'em up!
    RwP
    PNW
    6,588
    See diagram below...
    Not sure why shielding it doesn't work, tho.
    Aug 2004
    2,026
    No.
    RwP
    You know, I find your response to be pretty obnoxious. I don't know how old you are but, I wouldn't expect something like that from an adult.
    Aug 2004
    2,026
    Picture of my dash
    Okay Gentlemen. Attached is a picture of my dash from the passenger's side. I hate to be the bearer of bad news but, there's nothing on the driver's side of my dash. There is on the passenger's side a series of slots and a round clean lens.
    PNW
    6,588
    Looks like you're in the right area: C274
    Jan 2010
    Bossier City, LA
    2,221
    Hrm ...
    Here's the page from the FSM as an attachment that shows where it's SUPPOSED to be.
    1995_MN12_Light_Amplifier_RandR.pdf
    Edit: Added the EVTM page that shows the wiring to the light amplifier; that may help as you're inside the dash, to verify wire colors.
    1995_MN12_AutoLamps_Schematic_1.pdf
    RwP
    Last edited by RalphP; 08-01-2017 at 05:42 PM. Reason: Added the wiring diagram for the light amplifier
    Aug 2004
    2,026
    The slots and the lens have been taped off and the lights now work as expected whereas before I just had the lens taped off. Thanks!
    PNW
    6,588
    All's well that end's well - thanks for the followup and good luck w/your ride.
    Ken
    Oct 2006
    Valparaiso, Indiana
    378
    I'm assuming you want the headlights on for safety reasons? You could always add a daytime running light module from a Canadian car. I just came across a module on ebay two weeks ago. Its plug and play and will keep you from clocking all of that time on your interior and tail lights when its too bright for them to be useful anyway.
  1. 94-95 headlight
    By smokymance in forum Parts for Sale
    Last Post: 02-19-2006, 02:36 PM
  2. 94-95 headlights,corner lights,fog lights
    By Burbank95sc in forum Parts for Sale
    Last Post: 03-04-2005, 04:23 AM
  3. 94-95 headlight housing
    By T@Sound-Xtreme in forum Technical Forum
    Last Post: 06-15-2004, 11:24 AM
  4. 94-95 Headlight Swap, Having wiring problems.
    By mn12sc35th in forum Technical Forum
    Last Post: 01-22-2003, 08:39 PM
  5. FYI - 94/95 headlights (price from Ford)
    By tbird88 in forum Non Technical Forum
    Last Post: 01-05-2003, 12:51 PM
