Results 1 to 9 of 9
Thread: Injector harness
    Oct 2015
    Northern IN
    10
    Injector harness
    Anyone know what this connector is for?
    My car cranks but won't start.
    Tbird harness https://imgur.com/gallery/Z09s0
    May 2012
    Denver Area
    803
    Would help if we saw a detailed photo of the face of the connector please.
    Oct 2015
    Northern IN
    10
    https://imgur.com/gallery/M8uKe
    Here's the face is almost right behind the supercharger
    Jul 2005
    406
    Quote Originally Posted by Zodiac View Post
    Good morning
    The connector in question is for the EGR sensor. Located in the back of passenger side cylinder head. The sensor is attached to a bracket. See attachment:
    http://www.sccoa.com/forums/showthre...546-EGR-sensor
    Oct 2015
    Northern IN
    10
    Does that have to be plugged in to start? My car doesn't have the egr anymore.
    Jul 2005
    406
    Good morning
    The connector does not need to attached to the EGR sensor to start the engine. I assume the ECU does not have a EGR function?
    PNW
    6,586
    Is the upshift light on while cranking?
    See http://mnharms.com/tutorials/disnostart/
    Oct 2015
    Northern IN
    10
    No the upshift light isn't on.
    I had thought he head gaskets were blown so I went and pulled the motor and replaced them. Got it all back together it fired right up. Turns out I had 4 cracked pistons instead. So I got the engine out again and pulled pistons out of a donor engine and replaced them. And now it cranks but doesn't start.
    PNW
    6,586
    Good info, thanks for the details...
    Got it - that no-start troubleshooting linked procedure is your friend, I think. Just be sure to do the basics, such as a charged battery, and fuel in the tank, w/pressure at the rail.
    Good luck.
  1. Injector Harness
    By TBirdJKC in forum Technical Forum
    Last Post: 06-07-2008, 11:28 AM
  2. injector harness
    By dangerousdave69 in forum Want to Buy
    Last Post: 05-12-2007, 09:38 AM
  3. Injectors Harness
    By Car2n in forum Technical Forum
    Last Post: 03-28-2006, 03:45 PM
  4. Injector harness
    By Jake in forum Technical Forum
    Last Post: 10-23-2005, 04:46 PM
  5. ? on extending injector harness
    By V6Sprout in forum Technical Forum
    Last Post: 08-25-2003, 11:42 AM
