Results 1 to 11 of 11
Thread: Problem:Car is revving up when put in park.
    Mar 2016
    Jeannette Pa
    29
    So just today my 1990 cougar xr7 has started to rev up from normal idle to 2500 to 3000 rpm when i put it in park. I also don"t have to give it any throttle from 0-35mph. Can anybody tell me what is wrong. I looked to see if the car has a TPS Sensor and when i looked up A TPS Sensor on the Auto zone and Advanced Auto Parts websites nothing came. Does that mean the car is drive by cable. Please let me know what is going on and how to fix it.
    Dallas, TX
    5,641
    Your IAC is likely to blame. Its the assembly straddling the throttle plate that controls the amount of bypass air and hence the idle speed. You need a new one.
    20,886
    I agree that it sounds like the IAC valve. When you shut it off does it make a sound that sounds like a honking goose is under the hood ?
    Oct 2005
    Southwest of Kansas City
    2,264
    TPS and IAC locations.
    Jim, SCCoA Member#: 2789
    "cuz Jim has mad skillz, yo!" Melon.
    "You guys crack me up talking about nitrous when you don't even know if you can keep it together on gasoline." XR7 Dave
    "I didn't break it, I found it's weakness."
    Oct 2005
    2,264
    Parts on RockAuto.com
    I used a 1990 Thunderbird SC as the car but the parts are the same for both.
    IAC
    http://www.rockauto.com/en/catalog/f...ac)+valve,6072
    TPS:
    http://www.rockauto.com/en/catalog/f...sor+(tps),5136
    Mar 2016
    Jeannette Pa
    29
    Yes it does sound like a goose honking under the hood when I turn it off
    Mar 2016
    Jeannette Pa
    29
    Thanks for the help guys I will probably replace both just to be safe.
    Greenville, IN
    4,220
    Quote Originally Posted by Nkuk35 View Post
    You'd probably better off with an original Motorcraft TPS that still works over an aftermarket new one.
    The IAC will take care of the problem.
    Matt Haub
    20,886
    I agree...I've seen several of the aftermarket ones that didn't work properly. You can usually pick up a good used one for $15 to $20 in the classified forum.
    Jun 2015
    South Central PA
    52
    This aftermarket IAC worked for me
    Check out this thread. This one works well for me.
    http://www.sccoa.com/forums/showthre...rt-works-great
    Mar 2016
    Jeannette Pa
    29
    replaced the TPS sensor waiting for the IAC Valve. I received and email last night from partsgeek.com that they don't have the part in stock. Just a waiting game now.
  1. WHEN, is it time to put in NOS ARC Shocks!
    By Peterdroy66 in forum Super Coupe Club of Ontario
    Last Post: 03-11-2012, 05:45 PM
  2. Car stalls when put in gear!
    By DyingtoLive in forum Super Coupe Club of Ontario
    Last Post: 01-20-2004, 11:50 AM
  3. Rpm's Drop When Put In Gear?
    By Diggs in forum Technical Forum
    Last Post: 10-04-2003, 08:28 PM
  4. "Clunk" from rear end when putting in gear
    By XsithX in forum Technical Forum
    Last Post: 10-03-2003, 05:25 PM
  5. Electrical Problems: Car is DEAD! Help PLEASE
    By Tim Groth in forum Technical Forum
    Last Post: 06-21-2003, 10:02 PM
