Thread: 97 Mark VIII won't start after new plugs installed
    Aug 2009
    Kentucky
    122
    Help! I just installed new Motorcraft spark plugs (the OEM Platinum plugs it calls for) in my 97 Mark VIII and now it won't even fire when I crank it. The coils (it is a 1997 so it has coil-on-plug) all look good and seem to be firmly seated on the spark plugs and the input plugs seem OK too.
    It ran fine before I changed the plugs (just changed them because they had 75k miles on them).
    Thanks for any insight you can provide.
    Dallas, TX
    5,705
    Well I can't tell you much about the Mark 8, but I would look at anything in the area, where you were working, that might have been disconnected. Wiring harnesses, fuses, etc. And double check firing order from the coil.
    Aug 2009
    Kentucky
    122
    Well, it seems that the crank sensor went bad at exactly the same time I changed the plugs. So after switching plugs three times I figured it out. Ugh.
  1. 97 Mark VIII LSC cheap
    By k9t8m in forum Cars for Sale
    Last Post: 05-31-2006, 09:32 PM
  2. 97 Mark VIII LSC
    Last Post: 05-21-2006, 01:46 PM
  3. HELP PLEASE Won't start after tune-up
    By free90sc in forum Technical Forum
    Last Post: 02-01-2006, 06:30 AM
  4. SC won't start after a rain ????
    By John Valerioti in forum Technical Forum
    Last Post: 07-31-2004, 06:00 AM
  5. Car won't start after installing new dashboard
    By metalman in forum Technical Forum
    Last Post: 07-07-2004, 11:55 PM
