Results 1 to 6 of 6
Thread: Heat pouring out of center console
    Aug 2009
    Kentucky
    120
    Another Mark VIII problem: Heat constantly comes from the center console in my 1997 Mark VIII; a lot of heat. If feels like the heater is on full-blast and exiting into the console but there is no "wind", just heat. Both the AC and heat work normally but the AC is barely enough to overcome the heat emitting from the center console.
    I know that Mark VIII's are notorious for blend door failures. The guy I just bought the car from said that he just had the blend door fixed before I bought it so I suspect this has something to do with it but since the HVAC seems to function correctly, I am perplexed.
    Any ideas?
    Jul 2016
    64
    I know in my 89 SC the transmission bled alot of heat into the car that could be your issue?
    St. Louis, MO
    6,427
    What about a clogged CAT? Those things get super hot if clogged.
    Just a thought!
    Kurt K (e-mail)
    SCCoA Member #: 443
    '92 SC AOD -- 11.521s @ 116.748mph, 2.0 AR power
    . . . . . . . . . -- 13.547s @ 101.01 mph, only w/ bolt-ons
    '95 SC 5spd -- All Stock, except 17" Simmons wheels.
    '90 SC 35th Anny 5spd -- 3rd owner, 16k miles
    2 '89 XR7 5spd's -- on their way out, really!
    5,696
    How about a blend door problem due to a faulty vacuum line or ruputured diaphragm. Or a malfunctioning climate control.
    Jan 2011
    merced, ca
    28
    heat
    I have a 93 SC 78000 mi , 5 speed manual. Alot of heat inside of console and by shifter. removed console and shifter cover. Stock, there is no insulation around the shifter . So I surrounded the shifter with insulation I pulled from a SC at pick n pull. I also added more insulation under the console. The heat problem is gone. Hope this helps. My SC is completely stock low mileage car.
    407
    Good evening
    I believe it is a blend door issue. Well known with the Mark VIII community. Go this site for additional information. www.markviii.org
    Attachments.
    http://www.markviii.org/LOD2/emergency_heat.htm
    http://www.markviii.org/LOD2/blend_door_repair.htm
  1. Replies: 5
    Last Post: 10-04-2005, 01:54 PM
  2. Coolant pouring out of new engine
    By 92superJRK in forum Technical Forum
    Last Post: 05-09-2005, 07:58 PM
  3. What's Do You Want MOST out of your SC!!!
    By ReDevilXR7 in forum Polls Forum
    Last Post: 04-22-2005, 03:41 AM
  4. how to get center console storage area out
    By pdennis93 in forum Technical Forum
    Last Post: 10-28-2002, 11:18 PM
  5. Mark Martin breaks out of his slump
    By cary Jackson in forum Non Technical Forum
    Last Post: 05-29-2002, 12:17 AM
