Results 1 to 11 of 11
Thread: Recommended re-manufactured alternator brands?
    Dec 2015
    Daytona Beach, FL
    223
    So a month ago I replaced my factory Alternator with a Duralast one (save the laughs for later, I know I screwed up ). I read the reviews, but decided to risk it. I just needed something immediately, and my Autozone had one in stock. This morning, as I'm about to leave for school, battery light on. Immediately knew it was the alternator. Took it in, tested it (it failed), and they miraculously gave me a complete refund (including the core charge) so I could buy a different brand. So now I'm looking for another brand to go with. My mechanic here in town said he could get me one from his parts supplier, but I'm waiting on a call back from him for a price and brand. My local Ford Dealer said they don't make the Motorcraft ones anymore, and quoted me $350 for a re-manufactured Mitsubishi unit.
    I don't have the old alternator (or else I'd just get that one re-manufactured, shouldn't have turned it in to Autozone, big mistake). So I just want to know which brands you've had luck with in the past, or others I should shy away from.
    Thanks a bunch!
    Joseph Betros
    PNW
    6,591
    Quote Originally Posted by Roboplex View Post
    I believe that's who made the originals that the factory used.
    Shop warranty, as always
    But here's the deal - the fastest way to kill a fresh SC alternator is to install it with a dead/drained battery and expect the alternator to bring the battery all the way back up. Avoid that by using a battery charger first.
    Jul 2005
    408
    Good afternoon
    I am not a fan of re-manufactured alternators and started from stores. So far I have had nothing but bad luck. So I decided to have failed units repaired at a local highly recommended rebuild shop. One of the best things I have done for the car. But this doesn't help in your case. If you are look for a new alternator try this company. For all supercoupe year 1989 -1995. Pricey but less than $300. In the bellow attachment I used model year 1993
    http://catalog.oehq.com/item.wws?sku...RAFT&weight=10
    Good Luck.
    Dec 2015
    Daytona Beach, FL
    223
    Yup the last one was installed with a fully charged battery, so I'm fairly certain it was just refurbished with shoddy components, and that's why it failed.
    Dec 2015
    Daytona Beach, FL
    223
    Quote Originally Posted by sam jones View Post
    Good afternoon
    Good Luck.
    I did just find an ACDelco unit online for $125. I looked in the specifications and it says it was built by Mitsubishi. 24mo/24k mile warranty. KMT said the OEM units were Mitsubishi, would this be a good one to pick? I looked at the one you sent me, it's a little out of my price range at the moment, but I might be able to make it work if I have no choice.
    PNW
    6,591
    And how much for shipping on it?
    Dec 2015
    Daytona Beach, FL
    223
    Only $9, ends up being cheaper than the one I bought from AZ.
    PNW
    6,591
    I usually prefer doing parts like this locally, but since that hasn't worked out for you so far, this doesn't sound like a bad deal.
    Good luck w/whichever one you end up with this time.
    Ken
    Dallas, TX
    5,696
    I REALLY don't like non store suppliers for these units. The reason being since their likelihood of failure is so high, and since they are so difficult to verify that they have failed, you can't easily return them when they do. I stick with the local Azone, Oreillys, etc.. because I can drop the anchor on their counter and get a refund/replacement right then and there.
    When I say not easily verified, what you will often see is the alt will gradually fail occasionally. Thats the regulator circuit cutting out (I suppose it could be the diodes, but I don't have anyway to test the unit under a load). When the unit cools down, and you remove it to have it "bench tested".. it will pass about 90% of the time.. at the counter. You go through this exercise of reinstalling, and using your own volt-meter to check it out and damm..... its working again.. But only until it fails again.. only THIS time, you're left stranded. (Rinse and repeat!) Until it FINALLY fully fails and will test consistently as bad.
    So you take it in, and finally convince the store that its bad.. and they order you a new unit.. cross your fingers.. charge the battery, and HOPE and PRAY that this one holds up. Your chances of getting a good unit are about 50%.
    BTW, the only way you can see this is to keep a volt meter plugged into some power source in the vehicle somewhere.. e.g the cigarette lighter. Then watch as you see the output drop to 12V (batt voltage) on the display with the engine running
    Greenville, IN
    4,329
    I disassembled a couple of remanufactured ones...yeah, they don't care about the work they're doing.
    One had the front bear fail (in a few thousand miles)...when I took it out, I found that the bore in the case wasn't even round.
    Rebuilding one yourself isn't hard, if you can find the parts.
    And yes, the factory alternators were made by Mitsubishi.
    Matt Haub
    Dec 2015
    Daytona Beach, FL
    223
    So I ended up ordering the one from my (SC friendly) mechanic. He said if it fails within a year, I can get a full refund from him. He also said that he's never had a problem with them. $150 even. Im thinking I'll just see how this goes, if it fails, I'll just shell out the money for the Motocraft one.
  1. Re-manufactured Coated for the M90 from Magnum Powers
    By Magnum Powers in forum New Products and Services
    Last Post: 09-25-2012, 10:26 PM
  2. Getting the maganflo res/Dynomax muff setup tuesday...
    By 91BLOWNSC in forum Non Technical Forum
    Last Post: 05-28-2002, 12:15 AM
  3. Need New Shock Recommendations
    By 89SC in forum Non Technical Forum
    Last Post: 05-22-2002, 04:57 PM
  4. going to the parts store. WHATS THE BEST BRAND MOTOR MOUNTS?
    By supafly223 in forum Non Technical Forum
    Last Post: 05-17-2002, 11:36 AM
  5. Anyone re-drilled rims? Ie. 4 1/2 rim gets a 4 1/4 pattern.
    By BlackAnSC in forum Non Technical Forum
    Last Post: 05-13-2002, 02:02 PM
