Thread: Alignment problems
    Feb 2013
    bohners lake wi
    115
    Alignment problems
    I recently had my alignment done after replacing my lower control arms do to a bad ball joints. My car just broke luckily right by a stop sign. I'm trying to determine if it was my mistake or the shop I went to. What happened is the nut that holds the bar that goes from the frame to the control arm came off. Is it likely that I didn't tighten it up? Or is this something that would have been loosened to adjust the caster?
    Jul 2005
    Palos Heights
    2,297
    loose
    I Road Course my car.......had one back off ......but ........track time puts a lot of stress on the car
    Feb 2013
    bohners lake wi
    115
    Thanks. I kinda figured I didn't tighten it good enough. The adjustment appears to be done on the frame side and i had the cap nut come off.
  1. Rear Alignment Problems
    By Quik95SC in forum Technical Forum
    Last Post: 10-05-2005, 01:11 PM
  2. Alignment Problems/Questions
    By rad_al_ in forum Technical Forum
    Last Post: 04-03-2005, 11:06 AM
  3. alignment problems
    By dakotaflstf in forum Non Technical Forum
    Last Post: 10-27-2004, 11:42 AM
  4. Replies: 9
    Last Post: 11-29-2002, 01:35 AM
