Thread: Pulling code 77 1990 XR7
    May 2004
    Marlton, NJ
    136
    What part might this be?
    Salem, OR
    6,290
    Nothing - that code is simply a complaint by the system during testing/code reading that the process wasn't followed correctly - at the point where you're supposed to give it full throttle, it means to the floor...goose the heck out of it - put your foot in it - don't be shy. Otherwise, you'll get a fail/code 77 & not collect all the info available.
    When pulling codes (always a good thing), be sure the engine is fully warmed up, full throttle, 1/2 turn on the steering wheel wheel, and hard on the brakes when indicated.
    See: http://www.njtacc.com/tech/eec_codes.html
    May 2004
    Marlton, NJ
    136
    Thanks
    Thanks you very much
  1. How to pull codes
    By dsecker in forum Technical Forum
    Last Post: 10-25-2002, 02:57 AM
  2. 1990 xr7 convertible
    By 89xr7man in forum Non Technical Forum
    Last Post: 10-18-2002, 09:49 AM
  3. Pulled codes...Cant hold IDLE
    By Bigme574 in forum Technical Forum
    Last Post: 09-10-2002, 02:11 PM
  4. can't pull codes
    By Slysc in forum Technical Forum
    Last Post: 08-13-2002, 08:50 AM
  5. 1990 XR7 for sale
    Last Post: 08-05-2002, 08:52 PM
