Results 1 to 10 of 10
Thread: 1995 5-speed runs fine, many extras
    Sep 2017
    6
    Anyone interested in a '95 5-speed before I offload it elsewhere? It runs fine, but idle takes a bit to kick down for some reason (vacuum leak?) I ran out of time and need to move. Engine still very strong.
    Extras:
    SCP 3" Fresh Air Intake, C&L 73mm MAFS with sampling tube for stock injectors, set of larger injectors with matching sampling tube (not installed), 75mm throttle body, screamin' demon coil pack, LiveWires plug wires, Magnum Powers big bore throat SC intake, SCP 3" hi-flow exhaust, headers, new battery, new motor mounts, B&M Ripper short throw shifter, SPEC stage 1 high performance clutch & rebuilt transmission.
    I have the original intake/MAFS/throttle body/SC intake
    Interior is pretty decent... carpet is great, leather has a couple of obligatory leather seam issues.
    Paint is showing it's age.
    $2500 in Annapolis, MD
    Sep 2017
    6
    Additional Engine photos
    Sep 2017
    6
    Additional photos showing paint & leather seams
    SCCoA Member#1257
    3,290
    Mileage? Contact info?
    Sep 2017
    6
    175k. Email barnettgd at gmail dot com and I can send phone # etc.
    Sep 2017
    6
    Quote Originally Posted by Gdbnet View Post
    Update on "Runs fine" The engine is strong, but after doing a check-out i'm trying to fix an oil leak from the oil pump gasket where it seals to the engine. Just replaced the oil cooler gasket which was needed (and much easier). Oil pump is good, but it appears to have gotten loose. (and I think I found the original gasket in the oil cooler :-D).
    Greg
    Sep 2017
    6
    Oil leak fixed (oil sender) and also rebuilt oil pump, new seal on oil cooler, and replaced camshaft synchronizer. Oil system is all good, and it runs strong again!
    Sep 2017
    3
    Still available?
    Is it 5 speed?
    Franklin,Mass
    387
    Opening line of the thread!
    Joe
    It's not a 97 Sport, it just looks like one!
    Oct 2017
    8
    Still available?
  1. Replies: 9
    Last Post: 05-31-2013, 04:47 PM
  2. 95 5-speed running like crap...
    By 91BLOWNSC in forum Technical Forum
    Last Post: 09-27-2004, 07:50 PM
  3. Runs Fine, CEL On, Code 185
    By aviationstation in forum Technical Forum
    Last Post: 09-07-2004, 11:53 PM
  4. Running fine one second; High idle the next
    By tbirdboy in forum Technical Forum
    Last Post: 04-22-2004, 09:57 PM
  5. Got it running, now many codes
    By Lewis in forum Technical Forum
    Last Post: 08-06-2002, 10:50 AM
