Results 1 to 4 of 4
Thread: Erratic speedometer?
    Aug 2014
    76
    Hey guys. As title. I have an erratic spedometer.
    It has always had problems jumping around up to 60mph at random, whether the car is moving or not.
    I have already swapped out the VSS. any other places to check?
    Neill
    394
    Good morning
    I would check:
    the instrument cluster electrical large gray connectors for suspect corrosion in pin wire(s), loose connector, and or chafe wire harness.
    http://www.supercoupeperformance.com...peedo-pic2.jpg
    http://www.supercoupeperformance.com...el-93-pic1.jpg
    the speedometer circuit board for suspect solder and or corrosion.
    http://www.supercoupeperformance.com...eedo-pic14.jpg
    If it no defects found replace speedometer.
    6,402
    Might just be the small plastic gears in the head unit...normal for them to go out after so many years - know if they've been replaced already?
    Aug 2014
    76
    Video for those interested!
    https://youtu.be/p9A-6VNslKc
    No idea whether the gears have been replaced at the moment.
    I will take the unit out tomorrow and check the connections. See what the problem could potentially be!
    Thanks for the pointers guys!
    Neill
  1. Speedometers
    By walunsf in forum Technical Forum
    Last Post: 12-13-2002, 06:14 PM
  2. Speedometer needle flickering
    By 91SCRed in forum Technical Forum
    Last Post: 10-19-2002, 08:49 PM
  3. Replies: 5
    Last Post: 08-24-2002, 10:01 PM
  4. Speedometer head wanted
    By james90sc in forum Super Coupe Club of Western Canada
    Last Post: 05-23-2002, 02:06 PM
  5. Anyone got a spare speedometer needle?
    By MN12 KID in forum Super Coupe Club of Greater New York
    Last Post: 05-02-2002, 11:56 AM
