Results 1 to 8 of 8
Thread: Driveline not centered
    Oct 2002
    Alberta, Canada
    42
    Has anyone had this problem with their car? My drive line is not centered on the body or put it anyway, the body’s drive shaft tunnel is not centered over the drive shaft. So when installing a larger diameter drive shaft, it becomes very apparent and just about causes an interference problem (there is about 1/16" clearance).
    http://www3.telus.net/public/vgfedor...6211resize.jpg
    I thought maybe I installed something wrong so I went back to pictures I took before disassembly and sure enough the old drive shaft was not in the centre of the tunnel.
    http://www3.telus.net/public/vgfedor...3611resize.jpg
    So what is the solution besides going to a smaller diameter drive shaft or back to the original drive shaft? Do you hack away at the body support arch or do you get a custom made transmission cross member support to move the engine/transmission over an inch?
    Vernon
    Alberta, Canada
    1990 SC Auto - Sold 2003
    1995 SC 5 speed - purchased 2002
    Imperial, MO (near St. Louis)
    4,343
    Your photo links do not appear to be working.
    The stock engine location is offset toward the passenger side of the body.
    Oct 2002
    Alberta, Canada
    42
    Pictures in original message are working now. If stock engine location is offset towards passenger side, then why not move the driveshaft tunnel over accordingly? Dumb move by Ford.
    Anybody got any solutions yet?
    Vernon
    Alberta, Canada
    May 2004
    Va. Beach,Va.
    7,001
    Quote Originally Posted by vgfedor View Post
    3.5" driveshaft instead of 4"...................
    That's what I have and although it is offset to passenger side it has plenty of clearance from the tunnel.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
    20,946
    That's normal and why most people use a 3.5" driveshaft. For additional clearance loosen up trans mount and crossmember and pry or push towards driver's side while retightening. That will usually provide another 1/4" clearance.
    East Hartford, CT
    3,468
    Big Fvckin Hammer.....for the win
    Brian Oatway
    '94 SC 2.6KB C4 Auto
    9.956 @ 135.12 mph 1.364 60'
    514rwhp/460rwtq
    "Super Uber Club Member" - per Ira
    SCCoA Member # 705
    May 2004
    Va. Beach,Va.
    7,001
    Quote Originally Posted by scrazy View Post
    big fvckin hammer.....for the win
    lmao........................:d
    SCCOA Member #2406
    Oct 2002
    Alberta, Canada
    42
    Drive shaft problems
    Thanks for the advice. I probably won't be going to a 3.5" drive shaft so the solution will be partly what David suggested (pry the transmission over) and a big hammer and/or grinder. It is mostly that arch support in the middle body that is causes the tight fit so a little hammering and a little grinding will help.
    Vernon
    Alberta, Canada
  1. Rear Wheels Not Centered
    By Cyboman in forum Technical Forum
    Last Post: 05-13-2011, 10:22 PM
  2. Replies: 21
    Last Post: 03-09-2005, 10:58 AM
  3. Fastest Mustang is 2003 not 2000 R
    By pro street rich in forum Non Technical Forum
    Last Post: 05-15-2002, 07:50 PM
  4. not a sc ?..but need some help
    By tbirdsc22 in forum Non Technical Forum
    Last Post: 05-07-2002, 04:08 PM
