Results 1 to 15 of 20
Thread: No power to fuel pump relay, why?
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Dec 2012
    Lincoln, NE
    25
    Have 91 SC has been running fine when some bolts holding pulley to harmonic balancer broke and others stripped out threads. Replaced Harmonic balancer and pulley, turns over but won't start. I assumed it had to do with the crank position sensor but when I checked for fire at the plugs I have spark. Noticed didn't hear fuel pump cycle when turning on key. Inertia sensor has continuity. Fuel pump relay hot wired and I have 40lbs of pressure. Spins over but doesn't try to start with 40lbs pressure. Apparently no juice to fuel pump relay and injectors? Checked high current fuses under hood, all have continuity and power to them. Any ideas on what to check next and how to check it would be much appreciated.
    4,326
    Quote Originally Posted by lfiers889 View Post
    Do you still have a stock balancer or replacement?
    Dec 2012
    Lincoln, NE
    25
    Harmonic Balancer
    The harmonic balancer is a used one with the pulley balanced to it. Same part number as original and inspected before installing, appeared to be exactly same.
    6,586
    Is that 40psi fuel at the valve on the rail?
    Is the multi-wire ignition switch down on the side of the steering column original?
    Did you confirm the balancer is fully plunged?
    12+ volts at the battery?
    Upshift or check engine light on while cranking?
    Vacuum line at the FPR dry?
    Dec 2012
    Lincoln, NE
    25
    Answers to questions
    The fuel line pressure is measured at the schraeder valve on the rail. The ignition switch is original. The balancer is torqued to 120 ft lbs and in line with the other pulleys. The battery is +12 volts. Upshift light and check engine light are not on when cranking. If FPR stands for Fuel Pump Relay there is no vacuum line in the trunk by the relay. Good questions, appreciate the help.
    Jul 2015
    Chicago
    113
    FPR= fuel pressure regulator. Located on hen. Back of the fuel rail toward the drivers side of the motor. Kinda under the whiper assembly.
    Dec 2012
    Lincoln, NE
    25
    The latest...
    Checked the timing just by cranking engine with timing light and it is at 10 degrees per spec. So conclude harmonic balancer is installed correctly. Monig on: Fuel pump relay in trunk has 4 wires; power (black/yellow), fuel pump (pink/black), coil power (white), and what I think should be coil ground? So when switch is on I have 12+ volts at power and coil power, nothing at fuel pump, and 10 volts at the coil ground. Obviously the relay coil wont actuate with no ground, but when I turn the switch off I get a short surge of about 10 lbs from the fuel pump. I am assuming this is due to the coil ground no longer having 10 volts and actually working as a ground? My Chilton refers to this coil ground wire as number 22 on the 60 pin and it is called FP for Fuel Pump. It is connected to the self test connector as well. Which speaking of I can't seem to find so I can run the self test and try to get some codes. I have looked by the AC drier near the firewall on the passenger side, near the master brake cylinder reservoir on the river side, and under the dash on both sides. Where the H E double toothpicks did the geniuses at Ford hide it? Other question I have is what would cause voltage to be in ground wire for fuel pump relay?
    406
  1. No power to ac compressor
    By Jake in forum Technical Forum
    Last Post: 06-12-2018, 08:36 AM
  2. Have to jump fuel pump relay for engine to run
    By Mike Puckett in forum Technical Forum
    Last Post: 04-18-2009, 05:16 PM
  3. No electricity to fuel pump
    By metalman in forum Technical Forum
    Last Post: 07-11-2004, 08:22 AM
  4. Where is the fuel pump relay on my 89 SC?
    Last Post: 04-18-2003, 11:33 AM
  5. Fuel pump relay
    By xracer9x in forum Technical Forum
    Last Post: 01-04-2003, 02:24 PM
