Results 1 to 9 of 9
Thread: 89 SC idling around 4K?!?!
    Sep 2011
    Brandon, MS
    19
    I was driving down the road and out of nowhere my car just revved up to about 4K rpm. I drove it home like that and when I start it now, it immediately jumps to about 3.5k-4.5k rpm and does not idle down. Any ideas on where to start looking for the problem? Could this be an easy fix... or should I just take it to a shop? Any insight would be appreciated!
    6,522
    Floormat hanging up?
    Checked the linkage at the throttle body? Is the cable still connected?
    Sep 2011
    Brandon, MS
    19
    No floor-mats, and all the cables and the linkage look fine...
    6,522
    Pull the air intake and confirm the throttle plate is closed with engine off - note the position of the lever on the outside - is it at rest, against the stop? ...then fire it up and see if that changes.
    Still no joy, pull the connector off the IAC, then fire it up...it should struggle to idle.
    Sep 2011
    Brandon, MS
    19
    Ok, I haven't looked at that, yet... I'll check it out tomorrow when I have more light! Thanks for the info KMT! I'll post an update once I know more. I really appreciate the help.
    Sep 2011
    Brandon, MS
    19
    Started car, No change in throttle position, no change when IAC removed
    6,522
    wow...4k rpm with the throttle plate closed - ouch. IAC doesn't sound like it's doing it's job - might be a severe vacuum leak there.
    Do you know where the supercharger bypass valve assembly is? Up on the intake, generally behind the supercharger hat/outlet?
    Note the lever's position with engine off, then start it up and see if it moves/closes.
    5,677
    If the IAC is good, then when you unplug it, the car will struggle to idle.. If it is bad, then unplugging it would result in no difference.
    Remove it.. look inside.. I'd be certain that the bellows is cracked..
    Aug 2004
    Panama city
    447
    change iac
    change out iac anyway i went through this years back on a 90 new iac from az was junk so i never considered that as an option finally switched out with a junkyard IAC AND ALL WAS WELL. hope it helps. leaned lesson oNly oem IACS FROM NOW ON
  1. 89 sc idle problem
    By 89 Super Coupe in forum Technical Forum
    Last Post: 05-28-2013, 10:54 AM
  2. anyone have an 89 SC owner's manual sitting around ??
    By thunderkid84 in forum Want to Buy
    Last Post: 08-22-2008, 11:53 PM
  3. my 89 SC is having trouble idleing
    By falczSC in forum Technical Forum
    Last Post: 02-25-2005, 01:48 PM
  4. Could EGR delete on 89 SC cause idle sputter?
    Last Post: 05-10-2003, 11:30 AM
  5. '89 SC 5spd
    By Kirk Bryan in forum Super Coupe Club of Ontario
    Last Post: 04-04-2002, 01:24 PM
