Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 76 to 90 of 128
Thread: Derek's Project GFP
  1. #76
    Dec 2015
    53
    Quote Originally Posted by dthompson View Post
    The acc brackets came from a 95 mustang 5.0
    So, if you're using a Fox water pump and crank pulley then you're going to run into some alignment issues with that bracket. Of course, if you're using a Fox water pump and crank pulley then you're also going to have fun getting a radiator and fan in there too unless you plan on putting the radiator in front of the core support.
  2. #77
    Sep 2012
    Raleigh, North Carolina
    694
    Quote Originally Posted by MaddMartigan93 View Post
    A 95 mustang is not a fox, its a SN95. Both accessory brackets, crank pulley, water pump, and alternator are from/for a 95 mustang, so they all match. The timing cover is from Jegs, but fits a 95 mustang. Im currently searching for a water pump pulley, but will find one that matches the 95 mustang. The water pump pulley came with the 5.8, but I had to open up the center hole to fit the mustang water pump. The harmonic balancer is the monkey wrench in the combination. I purchased a Power Bond PB1082SS. This is one of two PB balancers that they make for the 351w (28oz) that is SFI approved. This balancer does not space the 95 mustang crank pulley out far enough. Ford Performance Parts makes a M-8510-B351 crank pulley spacer. My plan is to purchase this spacer and then machine it to the correct thickness to allow the crank pulley to line up with the other pulleys. But Im waiting to get the power steering pulley first to make life easier to measure.
    I posted pictures of the radiator and fan set up that I am going to use already (on page 4 of this thread). From the pictures you can see that it clears the water pump snout, which is the closest interference. What I have not posted on this radiator set up is the fan controller and overflow reservoir. But there is plenty of room to tuck that stuff in somewhere on the driver's front side.
  3. #78
    Dec 2015
    53
    OK, cool. The pictures with the water pump on seemed to look like the long neck water pump instead of the short neck pump so that's why I was asking. I went through most of these things with my setup so that's I was looking at it.
    I recently changed my balancer and I went with the Professional Products SFI balancer which required a spacer and they make one of those that is correct for our application as well.
    Here is the one I bought: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Keep in mind that the picture is not accurate. The part I received is machined aluminum and is a very nice part. I'm not sure if that would work for your balancer or not though.
  4. #79
    Sep 2012
    694
    I wanted to document this in case there are some other gluttons out there wanting to try this swap. Trickflow makes a pretty nice elbow adapter for the throttle body for 94-95 mustangs (SN95 5.0). Its reasonably priced and does a nice job of rotating and lowering the throttle body to a more desirable position. What is not so obvious is that the trickflow intake has the fox throttle body bolt spacing, which is not the same as the SN95 5.0 bolt spacing. So the elbow has the fox bolt pattern on the intake side, and the SN95 bolt pattern on the throttle body side. I found this out the hard way, as the original fox throttle body that I bought did not fit the elbow. From what I can tell the IAC and TPS sensors are all compatible, so its just a matter of matching the throttle body to the elbow.
    Finally found a power steering pump/pulley from the 94-95 5.0... which is another hard lesson learned. The 94-95 mustang 5.0 power steering pump pulley is unique to those two years. I destroyed one in the yard when I pulled the brackets, because Im an idiot. I didnt realize i needed it, didnt have a puller, and didnt want to pay for the pump. So I destroyed it trying to save a few bucks... well that cost me $100. Most used part dealer yards would not sell just the pulley.
    Im not sure if the 94-95 mustang brackets are the best for this swap or not. Seems like I read on TCCoA that it was preferred, but they seem to be scarce around here.
    Anyways, just been doing a lot of thinking and planning trying to figure out how to route all the turbo plumbing. Hopefully Im getting close on that and will start fabbing soon.
  5. #80
    Dec 2015
    53
    Thumbs up
    So, yeah, unfortunately you learned the hard way on those two items. I'm sorry to hear it because I could have helped out since I had to learn the hard way pretty much too. The 91-93 MN12 5.0 also uses the same configuration as the 94-95 SN95 5.0 for the brackets, pullies and throttle body. The whole short neck water pump is what drives the whole accessory configuration. Wazee's makes a billet power steering pump pulley so it's something to keep in mind. The stock pullies are slowly becoming impossible to find too.
    I think you're past the things I can help with but if you run into something else that's weird just PM me and I'll do my best to relate my experiences. If nothing else I might be able to help you avoid doing the same wrong thing I did.
    It looks awesome though. I can't wait to see the finished product.
  6. #81
    21,016
    This brings back a lot of memories from my 93 SC converted to 347 turbo. You are starting to get to the part where you find that the devil is in the details.
  7. #82
    Sep 2012
    694
    Feels like I took a big step forward this weekend. I was able to get the v bands welded on the exhaust manifolds. Im new to welding (pretty much self taught by youtube and pestering folks who know how to weld with questions), so welding up to the cast iron was a little intimidating. I did a hefty pre-heat on my gas grill and wrapped the manifolds in a couple towels after welding and it seemed to do OK. It helped that I finally got a gas lens for the torch which made a world of difference for me on being able to see what I was doing. Im still waiting on a T4 to 3" vband adapter before I get too deep into the hotside,but finally feels like it is starting to come together.
    Name:  exhaust v band.jpg
    Hopefully there will be more fab photos in the next couple weeks. Maybe one of these days, I will even be able to start it... looks like it is going to be June now. I talked to my cousin... we are going to try and make the shootout this year if I can get this thing finished up in time.
  8. #83
    Sep 2012
    694
    I got some work done on the hotside the past couple weeks. I decided to support the turbo from the alternator bracket... hopefully the 1/4" rods will not transfer too much heat. The flange is a pretty nice ebay find, its a CNC piece transitioning from 3" tubing to T4 flange. The smaller tubes are 2.25" and they merge into 3".
    I'm still waiting on some smaller tubing for the wastegate. The parts you see were mocked up in the engine bay and tacked together. Then I pulled the motor to finish connecting the dots. Still need to remove the pan and add the oil return bung for the turbo drain. While the motor is out, I need to finish up the harness work, secure the 95 mustang throttle cable to the firewall (yup had to swap that to match the TB... the connection was different), and cut some holes for the turbo cold side.
    I scored a couple important things at the junk yard since my last post. They had a 95 mustang gt and I got the alternator bolts, the throttle cable and bracket, and the thermostat housing/water neck.
    Name:  hot side pass 01.jpg
    Name:  hot side driver 01.jpg
  9. #84
    Sep 2012
    694
    Got most of the dots connected before the turbo.
    Name:  hot side 01.jpg
  10. #85
    Sep 2012
    694
    My cousin and I thrashed on this thing for the past week. Its been tough and fighting us most of the way. Trying to work through some wiring and electrical stuff that I dont quite understand yet. I tried to hook of the EEC and QH in a hurry late last night and I may have damaged stuff. Hope its not too bad. I forgot to repair the eec ground wire connector by the battery and tried to connect to the QH unknowingly. The USB cable got really hot and it may have damaged the connector on the board... the usb cable is definitely damaged some on the connector that plugs into the QH. I guess the EEC may have tried to pull a ground through the usb? Something else that is weird is that the 12v and ground (pins 4-5) on the BA5000 slot maf seem to have continuity... I did not expect that. So now I am checking out all the wiring changes, and making sure everything is correct. I dont understand why the ignition coil wire (the smaller red/green in the main fuse box) )that I used to trigger the EEC relay I added seems to have continuity to ground. If i pull the ignition fuse it opens (that means the big red/green wire side has the continuity that pass it through the fuse). I dont know if this is normal or not, but it seems odd to me.
    I'll keep chipping away at it. Sucks, but GFP.
    Name:  installed 01 no turbo.jpg
    then intake tube is temporary. just want to get it fired first.
  11. #86
    Dec 2015
    53
    Looks awesome man. Good work. I'm sure you'll work through the wiring stuff.
  12. #87
    Dec 2002
    Wintersville, OH
    4,094
    The downpipe is the one that goes thru the hood, not the charge pipe
    Making woosh sounds since 2010!
  13. #88
    4,418
    Looking sweet, Derek.
    The continuity surprises probably aren't issues....remember....a resistor has continuity between each end too.
  14. #89
    Sep 2012
    694
    Im a little gun shy after making a mistake. I cooked the connector on my QH. After digging out some melted plastic from the connector, i was able to get the QH to connect and download and upload a tune (just connected to my laptop, no EEC). But i had to keep pressure on the cable to keep it from dropping out. Ive got some buddies that can solder that type of stuff, so Im going to try and get them to replace the connector for me.
  15. #90
    Sep 2012
    694
    quick update... I was able to make my QH work after some finagling... but the usb connector needs to be replaced. Moates is a decent company for sure. I contacted them and told them what happened and they are gonna fix/replace it for me. So Im sending that off Monday. I figured out a couple problems with the wiring and corrected that. One of those problems was i used the wrong diagram to wire up the slot maf. Its really pretty crappy IMO that SCT doesnt send any information in the box with the BA5000. I mean its a $200 meter and doesn't include any sort of paperwork? Hopefully its not damaged, I tried to test it out, but I cant tell if its working or not. I guess its a waiting game to get the QH back and then go from there. While i was testing the QH, the fuel pump was working with the key on and I didnt find any leaks on the new braided PTFE fuel lines.
  1. Saturday Sept 21st motor swap project
    Last Post: 09-20-2002, 12:11 AM
  2. project....
    Last Post: 09-13-2002, 12:49 AM
  3. Project "X" revealed!
    By ProjectX in forum Super Coupe Club of Ontario
    Last Post: 08-20-2002, 01:57 PM
  4. Project "Black Bettie" Status: The awakening is ne
    Last Post: 01-31-2002, 03:33 AM
  5. Project "Black Bettie" Status Report: 7/29/01
    Last Post: 07-29-2001, 10:56 PM
