Looks awesome. It's going to be close for clearance.
I know you got a deal on the intake but I'm wondering if something like this wouldn't be a better choice: https://www.trickflow.com/parts/tfs-515u1108
The price on just the upper that should mate with your existing lower isn't too bad from what I saw on eBay.
If I am not mistaken, the box intake is actually taller than what I have now.
Its been a tough week. We had to say goodbye to our 18.5 year old cat this week, which was really hard on me and the wife. Now im fighting off a cold, which left me worthless for a day and a half. But, I did manage to get one thing done this weekend and that is wiring up the EEC relay. There are a few wiring changes that need to be done to make the swap happen, and this is probably the biggest one. Im not going to post too much about the specifics here, as Dave Dalke (SCUinc) has documented this pretty well and copyrighted the information. I will say that for any non-paying members that read this thread, there is a great resource of wiring diagrams available on the members only portion of the site... way better schematics than the EVTM. I did some double checking and tracing of the schematic to make sure I understood what was going on. The SC uses the IRCM to power the EEC, and the 5.0 uses a relay in the main power distribution box. So I wired up a 40 amp relay using the wiring diagrams and DD's documentation and hid the relay in the power distribution box. I swapped out a connector on the 5.0 harness and and all that is left is to re-wrap the harness in electrical tape.
The EEC is from a 92 Thunderbird 5.0 and matching eec/engine harness.
The QH and BE that I already had with my last set up. I had to purchase a different strategy file to match the new EEC. It is gsalc from sailorbob to match the L1C catch code.
I have been looking at the engine wiring harnesses .....
What alternator bracket are you using?
The acc brackets came from a 95 mustang 5.0
So, if you're using a Fox water pump and crank pulley then you're going to run into some alignment issues with that bracket. Of course, if you're using a Fox water pump and crank pulley then you're also going to have fun getting a radiator and fan in there too unless you plan on putting the radiator in front of the core support.
A 95 mustang is not a fox, its a SN95. Both accessory brackets, crank pulley, water pump, and alternator are from/for a 95 mustang, so they all match. The timing cover is from Jegs, but fits a 95 mustang. Im currently searching for a water pump pulley, but will find one that matches the 95 mustang. The water pump pulley came with the 5.8, but I had to open up the center hole to fit the mustang water pump. The harmonic balancer is the monkey wrench in the combination. I purchased a Power Bond PB1082SS. This is one of two PB balancers that they make for the 351w (28oz) that is SFI approved. This balancer does not space the 95 mustang crank pulley out far enough. Ford Performance Parts makes a M-8510-B351 crank pulley spacer. My plan is to purchase this spacer and then machine it to the correct thickness to allow the crank pulley to line up with the other pulleys. But Im waiting to get the power steering pulley first to make life easier to measure.
I posted pictures of the radiator and fan set up that I am going to use already (on page 4 of this thread). From the pictures you can see that it clears the water pump snout, which is the closest interference. What I have not posted on this radiator set up is the fan controller and overflow reservoir. But there is plenty of room to tuck that stuff in somewhere on the driver's front side.
I wanted to document this in case there are some other gluttons out there wanting to try this swap. Trickflow makes a pretty nice elbow adapter for the throttle body for 94-95 mustangs (SN95 5.0). Its reasonably priced and does a nice job of rotating and lowering the throttle body to a more desirable position. What is not so obvious is that the trickflow intake has the fox throttle body bolt spacing, which is not the same as the SN95 5.0 bolt spacing. So the elbow has the fox bolt pattern on the intake side, and the SN95 bolt pattern on the throttle body side. I found this out the hard way, as the original fox throttle body that I bought did not fit the elbow. From what I can tell the IAC and TPS sensors are all compatible, so its just a matter of matching the throttle body to the elbow.
Finally found a power steering pump/pulley from the 94-95 5.0... which is another hard lesson learned. The 94-95 mustang 5.0 power steering pump pulley is unique to those two years. I destroyed one in the yard when I pulled the brackets, because Im an idiot. I didnt realize i needed it, didnt have a puller, and didnt want to pay for the pump. So I destroyed it trying to save a few bucks... well that cost me $100. Most used part dealer yards would not sell just the pulley.
Im not sure if the 94-95 mustang brackets are the best for this swap or not. Seems like I read on TCCoA that it was preferred, but they seem to be scarce around here.
Anyways, just been doing a lot of thinking and planning trying to figure out how to route all the turbo plumbing. Hopefully Im getting close on that and will start fabbing soon.
