Results 1 to 9 of 9
Thread: My observations on new Spectra Radiator CU1879 for 94-95 SC's.
    SCCoA Member#1257
    3,290
    So the 94 teal is getting a new radiator and a few other items. I opted for a Spectra Premium radiator since it is all-metal and has a limited lifetime warranty from Autozone. During the install I ran into a few things that I wanted to share with the group as FYI. At the end, even though the rad seems to be constructed well and seems like it will do the job, I don't think I would purchace the same brand again due to the issues during installation.
    Comparison of my old rad (I'm trying to find out what brand it is) and the new rad.
    1- My main problem with the rad is the fact that the outlet for the upper rad hose is in a different location than the stock radiator and other aftermarket rads. I had to cut my new Continental (which I understand is the old Goodyear) hose in order to make it fit. I used a set of hose cutters and after trimming both ends, the hose fits fine. It's OK if you're using aftermarket hoses but I would really HATE to have to cut a set of hard-to-find OEM hoses in order to make them fit.
    Spectra Premium rad at the bottom, old rad at the top.
    This shows the old OEM motorcraft hose with the OEM location vs the location of the new rad outlet (with modified new hose)
    Old Motorcraft hose vs new Continental hose...they're about the same size.
    OEM motorcraft hose with the amounts that I had to trim from the new hose to make it fit.
    2- Drain plug size seems to be different. In the rad that was removed, which is also an aftermarket rad, the thread size is m12x1.25. I had purchased a petcock with a drain (dorman Help! PN: 61123) which fits in the old rad, but does not seem to fit in this new rad. So, now I have to source one to install. The rad came with a plastic petcock with no drain. With the times I've had to drain the radiator recently, I refuse to install another petcock with no drain, so It's a bit of a hassle for me.
    3- Radiator had debris inside. As I was preping the radiator for installation I heard something rattling inside. After much moving around I was able to get the debris. This is what was inside. I've changed a handful of rads through the years, but I've never seen anything like it. This kind of looks like defects in manufacturing and sloppy quality control. I can easily see this get pulled through the cooling system and causing issues...busted water pump, plugged thermostat, or worse.
    After I get the right petcock I'm hoping quality will prove to be OK and I get many years of use but wanted to give you all a heads up. Caveat Emptor!
    Franklin,Mass
    387
    Are those new hose clamps in the 3rd picture? Looking to replace my OE clamps, can't seem to find them.
    Joe
    It's not a 97 Sport, it just looks like one!
    SCCoA Member#1257
    3,290
    Quote Originally Posted by Rodeo Joe View Post
    Joe
    They're not new. I reused my old clamps and just threw a crappy coat of spray paint on them. If you source new ones, I'd be very interested in the PN's.
    2,175
    Quote Originally Posted by CaifanSC View Post
    You mean something like https://www.amazon.com/gp/product/B005EMZYWS ? (Not sure what size you need; that's probably the wrong size.)
    Addendum: Here's a PDF with a list of possible part numbers; I don't know where to buy them in less than a case lot, but at least now we have possible part numbers (just have to figure out the size in MM): http://www.rotorclip.com/cat_pdfs/ctb.pdf
    Last edited by RalphP; 09-27-2017 at 01:09 PM. Reason: Added a list of part numbers by size of one brand
    Franklin,Mass
    387
    Thanks Ralph!
    Did some looking around after you posted this up. I found an AutoZone repair guide for a Dodge Durango. In the guide it mentions that the size of these clamps is stamped on the back of the clamp. Of course mine are turned where I can't see it!
    Joe
    2,175
    CalifanSC - can you note the numbers on the back of your clamps (off either set of hoses!) and post them here?
    Thanks much!
    SCCoA Member#1257
    3,290
    Thanks much!
    Heya Ralph. I was able to finish my radiator install tonight.
    For the top hose:
    Radiator end - 44
    Thermostat housing end- 43
    I was not able to get the number from the lower hose clamp at the water pump outlet. The lower rad hose clamp at the lower rad inlet originally was part of the OEM motorcraft hose (it actually came stapled to the hose and looks way different). I'm planning to do a bunch of work on the Chameleon car next so maybe I can get the number for the lower hose clamp at the water pump then, and post it next time.
    SCCoA Member#1257
    3,290
    By the by...this is what the OEM Motorcraft hose/clamp assembly look like:
    Franklin,Mass
    387
    Thank you sir!
    I replaced my lower hose years ago and I remember those wire type clamps on them.
    Joe
  1. *NEW* in box rear corner brake lights set for 94/95 SC
    By Crash00527 in forum Parts for Sale
    Last Post: 07-07-2014, 10:38 PM
  2. new headlights for 94-95 sc 125$ shipped
    By maxcool in forum Parts for Sale
    Last Post: 09-08-2005, 03:09 PM
  3. loooking for 94-95 sc
    By birdhousex in forum Super Coupe Club of Western Canada
    Last Post: 06-06-2002, 10:17 PM
