Results 1 to 5 of 5
Thread: Suspension Renewal: 35th Anniversary Out Of Storage
    Sep 2002
    Raleigh, NC
    6
    After over 10 years of being in storage, my 1990 SC is back on the road and running great! But the suspension is definitely shot in terms of absorbing or managing any shock. What is the current wisdom for the best parts to bring it back to nearly original specifications? I found some shocks and struts that would seem to work, but the information does not assure me that they will be compatible with the adjustable suspension.
    P.S. If you read this and happen to have an SC that you are parting out, there is a fastener for the cruise control linkage under the hood that I need.
    Feb 2016
    Cincinnati, OH
    146
    I would check out Super Coupe Performance. Bill has the O.E. shocks and struts in stock. He also has many other suspension parts of O.E. standards or better.
    Matthew "Dale" Johnson
    ~"If it looks dumb and works, it's not dumb"
    Sep 2002
    Raleigh, NC
    6
    Thanks!
    I just had a valuable conversation with Bill. I plan to go with this set.
    https://www.supercoupeperformance.co...et-of-four-262
    Mar 2011
    SF, CA
    218
    Before you take apart your suspension or complete your order for Tokicos, do yourself a favor and check out all of the rubber bits. This way, you can make one order for everything you need.
    I'm a bit surprised that you found the dampeners to have blown while sitting neglected. While leaking seals are within the realm of possibility, I would also believe that the old rubber bushings are more likely to have crapped out over time (rear swaybar endlinks, upper ball joint, frame to ball front LCA, etc.)
    Feb 2016
    Cincinnati, OH
    146
    Yes. Definitely give everything a good check. All my bushings and ball joints were bad after sitting 2+ years. I still have to replace all the rear suspension pieces.
  1. 35th For sale. Moved out of state and lost my storage
    By koopa1699 in forum Cars for Sale
    Last Post: 09-22-2014, 01:03 PM
  2. out of storage
    By stevexr7sc in forum Super Coupe Club of Ontario
    Last Post: 03-31-2007, 11:45 PM
  3. Problem with 92SC just brought out of storage
    By Ia92SUPRCUPE in forum Technical Forum
    Last Post: 03-30-2007, 08:19 AM
  4. parting out 35th anniversary, still have all parts
    By Bleed_Ford_Blue in forum Parts for Sale
    Last Post: 11-17-2004, 03:35 PM
  5. out of storage, some pics
    By supercharged95 in forum Non Technical Forum
    Last Post: 07-24-2003, 01:31 AM
