Results 1 to 11 of 11
Thread: Loud unnatural noise
    Jan 2016
    102
    I unplugged the coil pack to crank the engine so I could bleed the power steering system (long, long story), and when I plugged it back in and fired the car up there was/is a very loud knocking coming from somewhere on the driver side of the engine. I didn’t touch the plugs or wires.
    Thoughts?
    Jun 2005
    196
    Uh oh. Exactly how much cranking did you do with the coil unplugged?
    Jan 2016
    102
    Lots. It was very slow cranking because the battery was shot (replaced that today), but cranking nonetheless. It was to cycle ps fluid through the hydroboost system I just put in.
    Jul 2005
    466
    Good morning
    Is the sound "clacking" or a knocking? The clacking (sometimes known as a tapping) sound could be collapse hydraulic lifters. Check the oil level and Dirty Oil Deposits. Take appropriate action. If good try another restart. It has been my experience serviceable high mileage lifter issue noise should dissipate within 3 minutes after starting. If the car has be down for awhile the 3 minutes should be enough time to pump up the lifters.
    Jan 2016
    102
    Itís a metallic (I guess) tapping. Clacking might fit the description. The supercharger knocks a little, and this is a very different noise. Loud and sharp. Almost as if I was tapping a piece of metal with a wrench. Itís rhythmic, too, not intermittent like the supercharger knock. The car sat all winter, was driven from March til May (when the teves went), and sat all summer, being started once a month or so. I fired it up last week and it was totally fine. I only ran it for several seconds yesterday as I didnít want to cause any (more) damage.
    Why would appropriate action mean?
    Jan 2010
    Bossier City, LA
    2,290
    Quote Originally Posted by smac View Post
    If the oil is low, top it off. If the oil is dirty, change it and the filter.
    RwP
    Dallas, TX
    5,746
    If the last thing you did was to splice into the power steering lines, I'd look around there. Something you can do to narrow the search is take off the serp belts and start it up for a minute. That would at least eliminate the accessories.. power steering, alt, AC, waterpump, etc as the cause.
    Jan 2016
    102
    Alright, tomorrow Iíll run the engine for four minutes to see if the sound disappears, if not, Iíll pop the belt off and run it for several seconds, and then Iíll check the oil.
    Salem OR
    7,307
    Did you check the crank pulley/dampener?
    Jan 2016
    102
    How does one do this?
    Salem OR
    7,307
    Engine off, grab the pulley and see if you can move it in any direction by hand. Eyeball it for fresh scrapes, warping etc. Inspect all the fasteners to confirm they're tight and accounted for. Check the belt for damage, fraying, etc.
    Engine running, eyeball the pulley to see if it wobbles.
  1. Mid length headers noise/ loudness
    By 1FSTBRD in forum Technical Forum
    Last Post: 04-24-2014, 06:45 PM
  2. Loud humming noise????
    By Joey D in forum Technical Forum
    Last Post: 07-14-2008, 11:31 AM
  3. blower failed loud buzzing noise?
    By davidw in forum Technical Forum
    Last Post: 06-11-2003, 08:56 AM
  4. Loud Grinding Noise
    By IMPORTDESTROYER in forum Technical Forum
    Last Post: 03-03-2003, 08:52 PM
  5. Please make the bad noise stop....
    By Tubeamp in forum Super Coupe Club of Ontario
    Last Post: 05-22-2002, 02:57 PM
