Results 1 to 5 of 5
Thread: Tty bolts
    Oct 2017
    Williamstown nj
    15
    Tty bolts
    On tty bolts do you oil them and the underside or install dry? (HEAD BOLTS)
    1,542
    Since the torque spec is in degrees of rotation and not ft-lbs, it really doesn't matter. I usually use a little bit of oil or pb blaster on the threads just to prevent galling the threads, but you only want to use a tiny amount.
    That being said, if you are replacing the head gaskets, ditch the TTY bolts and get a set of ARP head studs. It will eliminate the speculation about the bolts, will hold the heads more securely which means less chance of the gasket blowing again, and if you do ever have the heads off again, you won't have to buy new bolts again.
    Oct 2017
    Williamstown nj
    15
    Tty bolts
    Yep arp studs is what im going with. Ty makes a lot of sense to stud it and if im taking heads off again for install of other performance parts etc for example, im not spending another 43 dollars to bolt them down again. And im thinking it would be a better removal and install just sliding them down the studs. Is there any clearance issues with valve covers?
    1,542
    No clearance issues with the valve covers, but you won't be able to slide the heads over the studs with the engine in the car, cause they will hit the shock towers.
    Oct 2017
    Williamstown nj
    15
    Tty bolts
    Gotcha thanks for the heads up
  1. looking for bolts...
    By 91 XR7 in forum Super Coupe Club of Western Canada
    Last Post: 05-07-2002, 02:25 AM
  2. how are the seats bolted down?
    By Kick Ass Kolenc in forum Super Coupe Club of Western Canada
    Last Post: 04-11-2002, 01:53 AM
  3. bolt pattern
    By ryan a harris in forum Super Coupe Club of Ontario
    Last Post: 03-23-2002, 11:50 PM
  4. need help turning bolts reward..!
    By flynbrd in forum Super Coupe Club of Northern California
    Last Post: 01-24-2002, 05:34 AM
  5. Harmonic Balacer Failure &/or Crankshaft Bolt
    By 5thWaveSC in forum Polls Forum
    Last Post: 12-19-2001, 07:02 PM
