Results 1 to 15 of 18
Thread: Offical SCCOA Top HP List
    Aug 2005
    Paoli Indiana
    4,705
    Casey A aron 805hp/750tq 4.2/m5/turbo
    Corey Binkiewicz 737hp/674tq 3.8/m6/turbo
    David Dalke 537hp/528tq 4.2/???/2.0ar
    Ryan Zimmerly 506hp/479tq 3.8/aod/2.1
    David Neibert 504/467tq 4.2/aod/2.3 whipple
    John Ludorf 484hp/455tq 3.8/m6/2.0l
    Keith Nichols 478rwhp/467tq 3.8/4r70w/MPx/n20
    Ziad Baroody 478hp/435tq 2.3L TVS 4.2 AOD
    Ricardo Alfonseca 471hp/441Tq 3.8/m5/2.1
    David Clark 470hp/469tq 3.8/m6/1.7/n20
    Randy Hunerkoch 459hp/557tq 3.8/m5/1.7/n20
    David Rowe 451hp /475tq 3.8/m5/turbo
    Michael Inch 444hp/523tq 3.8/m5/mpx/n20
    Christopher Wise 442hp/404tq 4.2/4r70w/d1sc
    Paul Smarsh 1990 35th anny 2.3 tv's 3.8 aod 437hp/401tq
    Chris Homan 430hp/464tq/m5/1.7
    Molly Norris 423hp/449tq 3.8/m5/turbsky
    90blkbird 402hp/407tq 3.8/m5/1.7
    Phillip Dalke 399hp/409tq 3.8/m5/mpx
    Jacob Royer 395hp/409tq 4.2/aod/whipple
    Derek Thompson 385/474 4.2/m5/mpx
    Daniel Michael Boyd 380hp/456tq 3.8/aod/mpxs
    Zach Casswell 370hp/339tq 3.8/c4/mpx
    William Yaunce 311hp/344tq 3/8/aod/mpx
    Jimmy White 306hp/388tq 3.8/m5/Magnaport 1 M90
    Matt Haub 301hp/375tq 3.8/m5/sport
    Jeff Bratton 273hp/347tq 3.8/aod/mpiii/300k stock longblock
    Benjamin L. Goering 272hp/347tq ??/??/??
    Kurt Sunday 250hp/338tq 3.8/aod/late model/190k stock longblock
    Rules:
    Must be a mn12 OR an SC engine
    Must be a FORD engine
    To be on the list you must post a dyno sheet
    I need hp/tq/engine/trans/power adder
    Someone please make this a sticky! I will update as i get more! The pulls posted here have all been verified with a Dyno sheet on the Sccoa FB post.
    93 SC Red Auto 111k
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    2018 Shootout Pro Street Runner Up
    4.2, 2.3 Whipple, 3.73s AOD
    422rwhp 11.360 /??? mph
    Dec 2002
    Wintersville, OH
    4,097
    What's a ford m112, and David has made over 500rwhp
    Making woosh sounds since 2010!
    Boston, MA
    7,450
    Mn12.........
    Aug 2005
    Paoli Indiana
    4,705
    Mn12.........
    Fixed it lol damn smart phone.....
    93 SC Red Auto 111k
    Aug 2005
    Paoli Indiana
    4,705
    Quote Originally Posted by neverfastenough View Post
    Going off the dyno slip he submitted.
    93 SC Red Auto 111k
    Jan 2005
    Northern Cambria PA
    1,638
    I did 456 hp 415tq actual 437hp 401tq corrected on a base tune by Dave D.
    Paul Smarsh 1990 35th anny 2.3 tv's 3.8 aod 437hp/401tq corrected
    Boston, MA
    7,450
    Can someone explain the whole corrected variable that happens at TI
    Madison, Ohio
    17,605
    As with any dyno test that is properly administered, there is a weather correction applied. Otherwise I could do a pull in January that no one could match. All dyno runs are (or should be corrected). There are, across the industry, typically two standards that are used. One standard is called just that - Standard- This corrects the numbers to 60deg and sea level standard air pressure. STD numbers are always going to be higher than the other more modern and popular standard - SAE. The SAE standard was developed to make numbers more realistic and repeatable. The SAE standard is 77 deg and standard 14.7psi ambient air pressure.
    TI's Mustang Dyno records both actual and SAE values based on weather station readings in the shop at the time. Most other reputable dynos also record and print SAE numbers. If you don't see SAE on your sheet, then it might be STD or actual values. Actual values vary the most. I know for a fact some of the cars here were dyno'd in the middle of winter and some were dyno'd in the middle of summer with 100 deg heat. SAE does not correct for a heat soaked intercooler or one that is literally frozen. Results will always vary.
    It's not a variable. It's a correction factor and it's an industry standard. That being said, EVERY shop will occasionally experience errors in software or hardware that can skew results. In the case of TI Dyno leading up to the 2017 Shootout, there was a fault in the calibration values that caused numbers to read 40-80hp low. For example, Ira's car dyno'd 427rwhp the day he left for the Shootout, but the error likely means his car was closer to 490rwhp. I can't prove that and so his car must stand on his old numbers.
    Things like this happen, but our dyno is quite literally one of the most accurate and consistent in existence. Period. And I stand on that. One of the "problems" that we often run into with dyno'ing cars here is that the car might be a fresh build, or it might have problems that are being diagnosed, etc. It's hard to get a reliable number under conditions like that. But as an example of how consistent the dyno is, we took a car that had been built quite a few years ago and was running fine and dyno'd it back in summer. In October we dyno'd the car again. Check the chart. Different day, different weather, look how close the result mirrored each other. The only real difference is that the one pull shows significant wheel spin and hence a lower torque reading in the lower/mid range.
    Email me here.
    Dec 2003
    Altoona IA
    3,237
    1990 5-Speed 2.73 gears 1.7 AR - 402 rwhp 407 rwtq
    Name:  2010 SC dyno.jpg
    Aug 2004
    KSRQ
    5,202
    Very nice!
    Aug 2005
    Paoli Indiana
    4,705
    Quote Originally Posted by Ira R. View Post
    Very nice!
    Ira post up yours!
    list updated!
    93 SC Red Auto 111k
    Aug 2004
    KSRQ
    5,202
    Quote Originally Posted by Jacob_Royer View Post
    Ira post up yours!
    list updated!
    I don't have it. Dalke posted it on the Facebook page.
    1995 5-Speed 478rwhp & 1.7 AR - 478 rwhp 413 rwtq / without any adders!
    It isn't the best run it ever made, only 18# boost on the base street tune after it was finished.
    https://www.facebook.com/photo.php?f...&theater&ifg=1
    Aug 2005
    Paoli Indiana
    4,705
    I have you updated over on the fb list I will update this one when I get to a pc again.
    93 SC Red Auto 111k
    Boston, MA
    7,450
    So how can we tell if the numbers are corrected or standard or gross?
    Seems like the list becomes less relevant without that piece of information.
    Jan 2003
    Woodbridge, VA
    5,190
    It should be printed on the dyno sheet. Like 90blkbrd it says SAE power and torque.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
  1. LETTERMAN's top 10 list
    By Ryan A Harris in forum Super Coupe Club of Ontario
    Last Post: 01-20-2005, 05:33 PM
  2. Unofficial Poll For Changes To The SCCoA Most Powerful List Rules
    By SeanMatteson in forum Super Coupe Club of Ontario
    Last Post: 06-14-2004, 12:48 PM
  3. My top cars list after 1990!
    By dirtybird91 in forum Non Technical Forum
    Last Post: 03-16-2003, 04:00 AM
  4. New SCCOA Dyno HP List (submit your entry here)
    By Bill McNeil in forum Non Technical Forum
    Last Post: 11-25-2002, 12:09 AM
