• QA1 Coil Over kits with custom brackets....How LOW can you go? It's adjustable!
  • 75mm Throttle Bodies....polished or cast finish
  • Aluminum subframe bushings
  • Tubular rear upper control arms
  • Vogtland lowering springs
  • Poly strut rod bushings (front) and OEM type rear strut rod bushings
  • BHJ Harmonic balancers
  • 3" cat back exhaust systems
  • Lower engine cradle braces
  • Rear torsional load braces
  • Pinion braces
ALL OF THESE AND MORE are ON SALE NOW at Super Coupe Performance....Merry Christmas!
