Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Speedometer out by 7kph
  1. #16
    Jul 2016
    64
    I noticed when going to my sisters place the speedo seemed to be reading a lot closer to what the speed sign was sign give or take a couple Kph.
    I'll have to double check to see if it does it at higher speeds. With winter now hitting were i live i won't be able to do much until spring.
    If it is a weak spring is it possible to fix? Thank you for all of the info so far guys.
  2. #17
    Pacific Rim
    6,736
    Quote Originally Posted by BossII View Post
    Very possible. They guy at the local speedometer shop took just a couple minutes and didn't even charge me. Took longer to find another spring that it did to change it. Of course that was with the cluster out of the dash and the head unit out of the cluster.
    If I were you, I'd find a used speedo head, then replace the gears... unless you know they've been done, then swap it in. You might not even need to visit a shop.
  3. #18
    Pacific Rim
    6,736
    Speaking of replacing your speedo - this is what you need: https://www.supercoupeperformance.co...ds-cougars-918
  4. #19
    Jul 2016
    64
    Thanks everyone for the info. I'll look into maybe fixing the issue or just ignoring it. Depends on how bad the speedo bugs me
  1. Help!! im getting out smarted by a lug nut
    By nwnsc in forum Technical Forum
    Last Post: 01-10-2010, 12:37 AM
  2. What would make a shifter pop out of 1st gear by itself?
    By skydivr7673 in forum Technical Forum
    Last Post: 02-27-2006, 01:20 PM
  3. Bird got checked out by cops for first time..
    By stas in forum Super Coupe Club of Ontario
    Last Post: 06-06-2005, 04:25 PM
  4. Mark Martin breaks out of his slump
    By cary Jackson in forum Non Technical Forum
    Last Post: 05-29-2002, 12:17 AM
