Results 1 to 9 of 9
Thread: Rod
    Rod
    Hey Guys,
    Just seeing if someone might be able to help. So, I have this bent rod and it needs a little love. At our annual STL/IL Christmas party, I picked a nice butane torch (thanks Tony Serno) and I figured I could heat the rod up and bend it back straight. I plan to clamp it in a vise and use a very long piece of iron rod in the small end of the rod to bend it back in shape.
    So, is there one certain place on the rod that I should be heating up so that I can get the rod as straight as possible? Once straight, I figured I would file down any rough places and slap it into the engine and call it good. The extra heat treating should make the rod stronger than what I currently have in the engine.
    So, any advice?
    SCCoA Member #247
    Hardcore TBU #5 (in tow)
    Oct 2005
    2,296
    What did you do?
    Did you hit the switch for the nitrous on your untuned SC?
    Jim, SCCoA Member#: 2789
    "cuz Jim has mad skillz, yo!" Melon.
    "You guys crack me up talking about nitrous when you don't even know if you can keep it together on gasoline." XR7 Dave
    "I didn't break it, I found it's weakness."
    Salem OR
    6,804
    What works for me is to soak it in warm salt water for at least an hour - as all connecting rods are made from memory metal, it will return to it's original shape on it's own, you just need to be patient. Be sure to remove the bearing shells first, as they are likely to swell, and unless you know the clearances have opened up, that's not something you want to entertain.
    Dilly, dilly.
    Jan 2003
    Woodbridge, VA
    5,182
    Just be lucky it didn't break. Then you'd have to pay someone to weld it.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Jan 2008
    71
    Dilly, dilly.
    add a splash of ginko biloba to help that memory metal do its job.
    don't leave it in there too long, or it'll swell up into a dinosaur.
    Jun 2008
    Columbia,SC
    623
    heat
    Make sure you have a continuous flow of cutting oil on it while heating, so it stays lubricated. I would think you should heat it all over...you might be able to achieve the same effect by grounding it on your car battery until it turns a nice cherry color...should be able to straighten it out after that.
    SCCoA Member#1257
    3,321
    usually just soak it in a bowl of water and put it 5 mins in the microwave. Happens to me all the time...comes out good as new!
    Apr 2003
    Ventura, CA
    1,799
    I se your problem: You forgot to put cotter pins in your castle nuts.
    Aug 2004
    KSRQ
    5,193
    Silly wabbit. Kicks are for trids....
  1. Hot Rod Power Tour in Lincoln, May 24th
    By Melon01 in forum Super Coupe Club of the Midwest
    Last Post: 05-22-2002, 10:35 PM
  2. Hot Rod Power Tour
    By Kurt K in forum SCCoA Events
    Last Post: 04-28-2002, 12:51 AM
  3. Jim...Question About Rods & Mains
    By Ripvanbl in forum Super Coupe Club of Northern California
    Last Post: 04-26-2002, 12:36 AM
  4. Blown rod
    By kevin898 in forum Super Coupe Club of Ontario
    Last Post: 02-18-2002, 09:34 AM
  5. Spring Rod Run
    By IH8CHVY in forum Super Coupe Club of the Southeast
    Last Post: 04-04-2001, 08:46 PM
