Results 1 to 6 of 6
Thread: ABS Brake Bleed
    Jan 2018
    3
    ABS Brake Bleed
    Hi - I found the old posts for this, but the pictures don't come up anymore. Does anyone have the process for bleeding the ABS Teves IV system without the special tool? I had to replaced the valve body under the pump. There was a guy named Mark on here that had come with a jumper procedure in the post here:
    http://www.sccoa.com/forums/archive/...p/t-45452.html
    I don't quite understand what should be jumped to which pigtail. Do I have to run a wire from the battery to the pump pigtail for 12 V power?
    Didn't want to screw up my new valve body. Thanks, Bill
    PNW
    6,376
    You mean early or late model SC - which year?
    Early doesn't need the special tool.
    Jan 2018
    3
    right, thanks, yeah..late...'94
    Madison, Ohio
    17,547
    I have the tool which I will borrow/rent for $25 if you want. For a deposit of $150, if you send it back to me within 30 days in good condition, I will refund $125. It's really straight forward and easy to use.
    Email me here.
    Jan 2010
    Bossier City, LA
    2,175
    This is a heck of a deal; I don't need it, but if I did, I'd take XR7 Dave up on this.
    My 25 worth (was 2, but inflation and what not ... )
    RwP
    Jan 2018
    3
    Thank you! I will email you!
  1. ABS brake problem, please help and advise!!!!
    Last Post: 08-30-2002, 03:35 PM
  2. Abs, Brakes< Quit!
    By Superloop in forum Technical Forum
    Last Post: 08-02-2002, 05:10 PM
  3. ABS / Brake Problem
    By 93scto in forum Technical Forum
    Last Post: 07-02-2002, 09:27 AM
  4. ABS Brake Problem
    By Mitch90BlackSC in forum Technical Forum
    Last Post: 06-27-2002, 06:26 AM
  5. ABS brake light comes on
    By JerryRed95SC in forum Technical Forum
    Last Post: 06-23-2002, 11:56 PM
