Results 1 to 8 of 8
Thread: Sunroof drain lines
    Sep 2002
    Lynn,MA
    122
    Sunroof drain lines
    How do I access the front ones? Thought it might have been clogged but its not, its either pinched or disconnected, has anyone run into this? Pictures would be great.
    6,426
    Aug 2012
    168
    I know they run down the a pillerthrew the floor and out behind the front wheel. Their is a plastick cover over the pinch welds at the verry front right before wheel wells start. Had dripping issue inside due to a sunroof seal that shrunk. Their is alot easyer way to pull sunroof out with out oulling whole tot off
    6,426
    I'd guess cutting it off would be near trivial - it's getting it back on that might not be so easy.
    Feb 2011
    642
    The headliner has got to come down in order to access the drain lines, it a pain for sure.
    If you think it might just be clogged you can take compressed air with a long nozzle air blower and try to unclog the drain by blowing air in it from the top.
    It's worked for me in the past. If you really think it's disconnected or pinched it's a whole lotta work.
    Feb 2011
    642
    KMT very nice cut-a-way view pictures
    6,426
    Quote Originally Posted by 1994blkbirdsc View Post
    .. try to unclog the drain by blowing air in it from the top.
    Good tip, that.
    Best not to try it from the drain exit point as you risk dumping years of gunk onto the seats...don't ask how I know. I ended up probing them clear with a piece of brazing rod.
    Jun 2006
    Hampton, VA
    320
    this is where I get the wet and mess my headlinerName:  SC_Moonroof inside01.jpg
    1992 Thunderbird SC
    In memory of my 90 Cougar XR7 1996-2006 and 1993 Thunderbird SC 2006-2016
  1. sunroof drain
    By bybowtie in forum Technical Forum
    Last Post: 11-08-2006, 09:22 AM
  2. sunroof drains
    By Ronald Wendt in forum Technical Forum
    Last Post: 09-16-2003, 12:29 PM
  3. Need help - beat by 2001 Impala LS off the line.
    By tbirdsc357 in forum Super Coupe Club of Ontario
    Last Post: 05-28-2002, 11:57 PM
  4. Line Locs
    By 68COUGAR in forum Non Technical Forum
    Last Post: 05-17-2002, 11:22 AM
  5. Shopping on line
    By ThunderSC in forum Polls Forum
    Last Post: 07-25-2001, 10:24 PM
