Results 1 to 8 of 8
Thread: water leaking but not from sunroof
    Jun 2006
    Hampton, VA
    321
    Guys, every time it rains I get the front area of the headliner wet, including the sun visors, passenger side more than driver, even leave a small puddle of water on my floor map, now I che the drains and they are draining good, and check the drain hose and is good too, any ideas?
    1992 Thunderbird SC
    In memory of my 90 Cougar XR7 1996-2006 and 1993 Thunderbird SC 2006-2016
    Franklin,Mass
    405
    A bad seal?
    Joe
    Dallas, TX
    5,706
    Check that your windshield seal isn't cracked. Take the A pillar trim off on both sides, and gently pry the top windshield trim straight up and off. search and read up on the best way to do this..
    Look around. Clean, and reseal with black RTV. I had a leak on my black car, which has the original windshield, from age that was due to the sealant drying and cracking.
    Milwaukee, Wisconsin
    3,329
    something people forget about...
    There are drain channel's that go down both sides of the roof. these get blocked with dead leaves and other crap. when this happens the water backs up and you have a flood... simple to clean just run a small wire down both sides and see if that helps you....good luck....Rich
    Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
    Pacific Rim
    6,727
    Quote Originally Posted by wingzeroac195 View Post
    Guys, every time it rains I get the front area of the headliner wet, including the sun visors - I che the drains and they are draining good, and check the drain hose and is good too, any ideas?
    See this thread for a look at the area involved: http://www.sccoa.com/forums/showthre...oonroof+drains
    If the drains are clear and the visors are wet, I'd suspect the seal on the moonroof itself and/or it isn't closing properly. Search here for sources on a new seal.
    Could be the window glass adhesive gave up, but I'd expect water from it to go down, not back, unless your issue is hard rain at freeway speed
    Can you make it leak with a gentle flow from a garden hose on the glass and moonroof?
    The drains on the rear corners are hard to check visually unless you pull the skirts, I think, but as you said, you checked them all, so...
    Apr 2012
    Dallas, TX
    448
    Evacuatuon hose can become lose
    As you can see in the pictures from the posted link above, there are four water evacuation channels. Often one or more can come lose (see the attached picture).
    The previous owner of that car had taped the roof because of a leak. Could not find the leak until we took the entire liner out of the car. Two hoses had come lose causing the leak.
    Check out my 1993 White Auto SC page for video on how to ..
    1990 35th anniversary SC restoration project
    1990 Blue Auto SC
    Pacific Rim
    6,727
    Quote Originally Posted by Falcon20x View Post
    Sometimes due to aggressive probing when trying to clear - be careful. If the outlet is plugged, even using compressed air can be risky. And if it seems like a good idea to come in from the outlet, think about where any gunk is going to end up...no fun trying to clean decomposed pine needles off seats/carpet
    Pacific Rim
    6,727
    http://www.sccoa.com/forums/showthre...es#post1115262
    ...I'd tape over the top of the glass long enough to manually water test just to confirm. You might need to take it to a glass shop and ask them for help re-sealing if that's the source. I think they have ultrasonic test equipment to help find gaps, etc.
  1. doors unlock but not lock from inside
    By mellbutler in forum Technical Forum
    Last Post: 05-31-2010, 09:33 AM
  2. Coolant Leak....but from where??
    By ben04 in forum Technical Forum
    Last Post: 06-06-2007, 08:39 PM
  3. wind noise from sunroof
    By jnobles in forum Non Technical Forum
    Last Post: 02-09-2003, 07:43 PM
  4. 94 sc air dam bottom ??? got frown, but not the lower????
    By lostsoul74 in forum Non Technical Forum
    Last Post: 12-25-2002, 12:28 PM
  5. Need help on this one but not for SC
    By hepcat in forum Non Technical Forum
    Last Post: 07-23-2002, 01:34 AM
