dthompson
I am placing my current engine set up for sale. The engine is still in the car and will be pulled by the middle of March. These parts will be for sale once the motor is out of the car. Pictures of individual items will be added then. These parts are clean and in great condition. I have included overall pictures of the engine bay (taken 2-17-18) to show the overall appearance.
The engine was built by HF Performance in Wilson, NC (a reputable engine builder in eastern NC). It has less than 8,000 miles on it since it was built. This set up made 384whp 471 ftlbs at the 2016 shootout (it may actually be slightly higher now since I have upgraded the valve springs since). The reason for selling this motor is because I am building a v8 for this car.
This engine is from an 89. If you plan on putting it into a late model car, I believe you will need to use the appropriate timing cover and crank sensor.
Please send me a PM and add a comment to this thread if you would like to purchase any of these items. If you have any questions about me or my car, feel free to ask others on this forum or the facebook group.
Thanks,
Derek
- Long Block Includes the following: $5000 (shipping/delivery arrangements extra, to be determined)
- Super Six Motorsports 4.2 rotating assembly: New 4.2 crank, SCAT forged stroker Hbeam rods, ARP rod bolts, 9:1 compression Wiseco forged pistons, rings, pins, and lox
- Super Six Motorsports Stage 3 Heads: Stage 2+ plus additional intake porting, high polished chambers, 1.88/1.57 stainless steel valves, .54 lift CompCams springs/retainers: 228 CFM intake/189 CFM exhaust. .83 exhaust/intake flow ratio (from their website at time of purchase)
- Super Six Motorsports Cam: billet hydraulic roller cams: Duration 218/224 Lift .545/.545 Rockers 1.7 LSA 112
- Comp Cams Valve Springs: Upgraded from the springs that came on the SSM heads. These have ~170lbs of seat pressure and ~390lbs open pressure with this cam.
- Super Six Motorsports Stud Mount Adjustable Roller Rocker Arm Kit: This kit is the ultimate adjustable roller rocker arm kit for the 3.8 and 4.2 and includes our custom CompCams 1.7 ratio rocker arms, studs, locknuts, guide plates, and shims
- New Lifters, Pushrods, Bearings, Timing Set, Timing Tensioner, Oil Pump, Water Pump, 180 Degree Thermostat, Oil Pressure Unit, Coolant Temp Unit, Pilot Bearing, and Head Bolt Kit. Rotating Assembly was balanced, Bore and Honed Block, Decked Block, Pin Fit Connecting Rods, Port Matched lower intake manifold, and Surfaced Flywheel
- Ignition components: New Motorcraft Cam Sensor, new crank sensor, new DIS module.
- Solid rubber motor mounts
- Custom FMIC Tubing $475 shipped ***SOLD***
- Kooks mid length headers $500.00 shipped ***SOLD***
- Early model (89-93) bhj balancer $300.00 shipped
This item new would cost $420 - fuel injectors deka 80s $200.00 shipped
This item new would cost $300 - MPX and inlet, NO pulley $1,300.00 shipped ***SOLD***
- MP raised top $225.00 shipped ***SOLD***
- MP 85mm TB $275.00 shipped ***SOLD***
- MP Springs/tensioners (springs are installed in the modified tensioners) ***TENSIONERS SOLD***
- MP 10% jackshaft 5% sc pulley $200 shipped ***SOLD***
- MP 10% crank pulley $225.00 shipped ***SOLD***
- 3.5 intake $75.00 shipped ***SOLD***
- Taylor Thundervolt wires $35.00 shipped ***SOLD***
- Intake Return manifold machined for 2.75” silicone coupler $75 shipped ***SOLD***
- Alternator Stock Replacement $75 shipped ***SOLD***
- A9U2 EEC $75 shipped
- Replacement jack shaft bearing NEW $50 shipped ***SOLD***
- Accessory brackets $40 each shipped ***PASS SIDE SOLD***
- Power Steering Pump (not for sale)
Thanks,
Derek
