Results 1 to 2 of 2
Thread: Oil pressure sensor location.
    Feb 2018
    1
    Just change my oil and filter on my 94 super Coupe, fired it up everything was fine drove down the road for ways and now I have no oil pressure on my gauge. I'm assuming my sensor went bad. Any other suggestions? And where is the sensor located?
    PNW
    6,518
    To the right of the water pump, under the accessory bracket, above the oil pump/filter - note this photo show the area, but don't be confused by the extra parts as this is from a thread discussing how to add a real pressure gauge, I think. The red push on connector will help locate it. I'd check that first, being sure it is clean and fits snug. Squeeze it a bit to grab better if needed. Might be it just came off.
  1. Quick help needed with oil pressure sensor
    Last Post: 03-10-2004, 03:32 AM
  2. Omitting steel tube for oil pressure sensor
    Last Post: 02-14-2004, 10:29 AM
  3. Sealing oil pressure sensor
    Last Post: 01-28-2004, 08:08 PM
  4. Oil pressure sensor shut off. XR7 Dave anyone
    By Blown347 in forum Technical Forum
    Last Post: 04-28-2003, 08:36 AM
  5. Oil Pressure Sensor
    By Valentino in forum Technical Forum
    Last Post: 02-18-2003, 12:34 AM
